Data sheet | Item number: 284-621
Distribution terminal block; 10 mm²; lateral marker slots; for DIN-rail 35 x 15
and 35 x 7.5; screw-type and CAGE CLAMP®connection; 3 x CAGE CLAMP®
connection 10 mm²; 1 x screw-clamp connection 35 mm²; 10,00 mm²; gray
www.wago.com/284-621
Color:
Item description
Safety information 1:
Screw torque: 3.5 Nm
Data
Electrical data
Ratings per IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated current
125 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Number of connection points (connection type)
3
Actuation type
Operating tool
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
01.06.2020 Page 1/10
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0,2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Strip length
12 … 14 mm / 0.47 … 0.55 inch
Connection technology 2
Screw-type connection
1
Solid conductor 2
6 … 35 mm² / 10 … 2 AWG
Fine-stranded conductor 2
Total number of connection points
4
Total number of potentials
1
Number of levels
1
Wiring type
Front-/Side-entry wiring
Geometrical Data
Width
17,5 mm / 0.689 inch
Height from upper-edge of DIN-rail
39,5 mm / 1.555 inch
Depth
89 mm / 3.504 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Torque
3.5 Nm
Material Data
Color
gray
Insulation material
Polyamide 66 (PA 66)
Weight
55.5 g
Commercial data
Packaging type
BOX
Country of origin
IN
GTIN
4045454282561
Customs tariff number
85369010000
Approvals
/ Certificates
Hansastr. 27
32423 Minden
01.06.2020 Page 2/10
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2160584.03
CCA
EN 60947
NTR NL7078
CSA
C22.2 No. 158
1536073
Approval
Certificate
name
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
UL-Approvals
Logo
Approval
UL
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20170731E45172
Counterpart
Hansastr. 27
32423 Minden
01.06.2020 Page 3/10
Compatible products
ferrule
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated
www.wago.com/216-108
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-262
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Jumper
Item no.: 284-412
Comb-style jumper bar; insulated; Nominal current 125 A; 2-way; gray
www.wago.com/284-412
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 709-154
Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent
www.wago.com/709-154
assembling
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Hansastr. 27
32423 Minden
01.06.2020 Page 4/10
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Hansastr. 27
32423 Minden
01.06.2020 Page 5/10
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Hansastr. 27
32423 Minden
01.06.2020 Page 6/10
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
General accessories
Item no.: 284-400
Finger guard; touchproof cover protects unused conductor entries; yellow
www.wago.com/284-400
Item no.: 709-311
B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/709-311
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft
www.wago.com/210-721
tools
Downloads
Documentation
Bid Text
284-621
Feb 19, 2019
xml
3.7 kB
Download
Sep 19, 2017
doc
25.1 kB
Download
Apr 3, 2019
pdf
Download
GAEB X81 - Datei
284-621
doc - Datei
Additional Information
Technical explanations
Hansastr. 27
32423 Minden
2.1 MB
01.06.2020 Page 7/10
2.1 MB
CAD/CAE-Data
CAD data
2D/3D Models 284-621
URL
Download
EPLAN Data Portal 284-621
URL
Download
WSCAD Universe 284-621
URL
Download
CAE data
Handling Instructions
Conductor termination
Terminating a 35 mm² (2 AWG) conductor –
Terminating a 10 mm² (8 AWG) conductor –
screw clamp connection, side-entry wiring.
CAGE CLAMP® connection, front-entry
wiring.
Connecting 35 mm² (2 AWG) conductors to
commoned terminal blocks.
Screw clamp connection, side-entry wiring
Commoning
Hansastr. 27
32423 Minden
01.06.2020 Page 8/10
Commoning with comb-style jumper bar.
Individual arrangement: 125 A
Two jumpers combined in one clamping unit:
100 A
Application
Hansastr. 27
32423 Minden
01.06.2020 Page 9/10
Side-entry distribution terminal block with
screw clamp connection (35 mm²/2 AWG)
and front-entry CAGE CLAMP® connection
(3 x 10 mm²/8 AWG) snaps onto DIN-35 rails
per EN 60715. This terminal block is
enclosed on both sides and requires no end
or intermediate plate.
When connecting 3 x 10 mm² (8 AWG)
conductors on the distribution side, make
sure that the nominal current of 125 A is not
exceeded.
Hansastr. 27
32423 Minden
01.06.2020 Page 10/10
很抱歉,暂时无法提供与“284-621”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+483.222642+62.63486
- 5+344.842755+44.69819
- 10+332.3296510+43.07625
- 25+315.1505825+40.84952
- 50+308.8903950+40.03808
- 国内价格 香港价格
- 1+447.427111+57.99508
- 10+326.2976710+42.29439
- 25+295.6344125+38.31985
- 50+277.7407250+36.00049
- 100+263.60178100+34.16781
- 250+249.51957250+32.34249
