Data sheet | Item number: 285-150
2-conductor through terminal block; 50 mm²; lateral marker slots; only for
DIN 35 x 15 rail; POWER CAGE CLAMP; 50,00 mm²; gray
www.wago.com/285-150
Color:
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
1000 V
Rated surge voltage (III/3)
8 kV
Rated current
150 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
16.06.2021 Page 1/13
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
150 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
150 A
Ratings per CSA
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
150 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group D)
150 A
Connection data
Connection technology
POWER CAGE CLAMP
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
10 … 50 mm² / 8 … 1/0 AWG
Stranded conductor
Fine-stranded conductor
10 … 70 mm² / 8 … 2/0 AWG
Strip length
30 mm / 1.18 inch
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Wiring type
Side-entry wiring
Physical data
Width
20 mm / 0.787 inch
Height
94 mm / 3.701 inch
Depth from upper edge of DIN-rail
87 mm / 3.425 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Hansastr. 27
32423 Minden
16.06.2021 Page 2/13
Marking level
Side marking
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.262 MJ
Weight
156.2 g
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
Packaging type
BOX
Country of origin
PL
GTIN
4045454507411
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7707
CSA
C22.2 No. 158
1151144
KEMA/KEUR
EN 60947
71101911
Ship Approvals
Logo
Approval
ABS
American Bureau of Shipping
EN 60947
DNV GL
Hansastr. 27
32423 Minden
Certificate
name
20HG1941090PDA
TAE00001V2
16.06.2021 Page 3/13
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
UL-Approvals
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
Optional accessories
Mounting
Item no.: 249-197
Screwless end stop; 14 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-197
Item no.: 285-448
Fixing element; for 50 mm² high-current terminal blocks; orange
www.wago.com/285-448
Potential distribution
Item no.: 285-447
Power tap; for 50 mm² high-current tbs; Module width 16 mm; 6,00 mm²; gray
www.wago.com/285-447
Item no.: 855-501/150-000
Current and voltage tap up to 50 mm²; Primary rated current: 150 A; Secondary rated current: 1 A;
Rated power: 0.2 VA; Accuracy class: 0.5; fused
www.wago.com/855-501
/150-000
Item no.: 216-109
Ferrule; Sleeve for 10 mm² / AWG 8; uninsulated; electro-tin plated
www.wago.com/216-109
Item no.: 216-110
Ferrule; Sleeve for 16 mm² / AWG 6; uninsulated; electro-tin plated; metallic brown
www.wago.com/216-110
Item no.: 216-209
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; red
www.wago.com/216-209
Ferrule
Item no.: 216-210
Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210
acc. to DIN 46228, Part 4/09.90; blue
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-414
Ferrule; Sleeve for 35 mm² / AWG 2; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-414
Item no.: 216-424
Hansastr. 27
32423 Minden
16.06.2021 Page 4/13
Item no.: 216-424
www.wago.com/216-424
Item no.: 216-425
Ferrule; Sleeve for 50 mm² / AWG 1; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-425
Item no.: 216-435
www.wago.com/216-435
Cover
Item no.: 285-441
Finger guard; touchproof cover protects unused conductor entries and jumper slots; for 50 mm² high- www.wago.com/285-441
current tbs; yellow
Jumpers
Item no.: 285-450
Jumper; insulated; gray
www.wago.com/285-450
Protective warning marker
Item no.: 285-440
Protective warning marker; with high-voltage symbol, black; yellow
www.wago.com/285-440
Item no.: 285-449
Protective warning marker; yellow
www.wago.com/285-449
Item no.: 285-172
Allen wrench; with a partially insulated shaft; green
www.wago.com/285-172
Item no.: 285-173
Allen wrench; with a partially insulated shaft; with anti-rotation protection; green
www.wago.com/285-173
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Tool
Carrier rail
Marking accessories
Item no.: 2009-115
www.wago.com/2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Hansastr. 27
32423 Minden
16.06.2021 Page 5/13
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-005
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 285-442
Adaptor; gray
www.wago.com/285-442
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Hansastr. 27
32423 Minden
16.06.2021 Page 6/13
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-014
/000-014
type; brown
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
Hansastr. 27
32423 Minden
16.06.2021 Page 7/13
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Downloads
Documentation
Bid Text
285-150
2019 Feb 19
xml
3.3 kB
Download
2018 Jan 4
doc
24.1 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
URL
Download
WSCAD Universe 285-150
URL
Download
ZUKEN Portal 285-150
URL
Download
EPLAN Data Portal 285-150
URL
Download
URL
Download
X81 - Datei
285-150
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 285-150
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 285-150
2-conductor through terminal block; 50 mm²; lateral marker slots; only for DIN 35 x 15
Hansastr. 27
32423 Minden
16.06.2021 Page 8/13
Installation Notes
Installation
Snapping a terminal block onto DIN-rail (to
the left or to the right).
Removing a terminal block from the
assembly (to the left or to the right).
Conductor termination
For the optimal clamping force:
Always observe the on-unit printed strip
length guide!
Conductor termination – step 1:
Rotate the T-wrench counter-clockwise to
the stop . Next, push in the orange locking
tab. The clamp is locked open for hands-free
wiring.
Bend conductor
Cut conductor to length (conductor
end must be straight)
Strip conductor
Hansastr. 27
32423 Minden
16.06.2021 Page 9/13
Conductor termination – step 2:
Conductor termination – step 3:
Insert a stripped conductor into the
clamping unit until it hits the backstop. Hold
in this position.
A short counter-clockwise rotation releases
the tab. When unlocked, the T-wrench
rotates clockwise, securely clamping the
conductor.
Commoning
Commoning with an adjacent jumper: insert
the jumper above the conductor entry hole –
prior to conductor termination. The nominal
cross-section remains unchanged.
Removing jumper via operating tool.
Cover
Hansastr. 27
32423 Minden
16.06.2021 Page 10/13
Protective warning marker may indicate:
Notice: Power is still on even after switching
off the main switch!
Yellow, detachable finger guards provide
touch-proof safety by shielding jumper
contact slots and/or unused conductor
entries.
Power tap
Easily and consistently tap directly into the
power supply. Insert the unwired tap before
opening the clamping unit.
Safety
Hansastr. 27
32423 Minden
16.06.2021 Page 11/13
Risk of Injury!
Do not insert fingers in the conductor entry!
Testing
Testing via touch-proof 4 mm Ø test plugs
(not available from WAGO, but offered by
industry suppliers such as, Multi-Contact
Deutschland GmbH).
Testing
Marking
Hansastr. 27
32423 Minden
16.06.2021 Page 12/13
WMB markers or self-adhesive, printable
marking strips can be accommodated on 35,
50 and 95 mm² high-current terminal blocks.
Marker carrier for marking strips (2009-110)
or 2 WMB markers for 285‑13x, 285‑15x and
285‑19x Terminal Blocks
Product family
POWER CAGE CLAMP
Show all products from the family
Hansastr. 27
32423 Minden
16.06.2021 Page 13/13
很抱歉,暂时无法提供与“285-150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1044.034901+135.25590
