734-104
734-104
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 1x4P
734-104 数据手册
Data sheet from 15.07.2010 Item no.: 734-104 Product description: FEMALE CONNECTOR 4 POLE PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODING FINGERS Produkt kann von Bild abweichen / product may differ Packing unit 200 pieces Product group 3 (Multi Conn. System) Weight 3.229 g Color light gray No. of connection Points 4 No. of potentials 4 pole count 4 Height 13.4 mm Height 0.528 in Width 16.2 mm Width 0.638 in Depth 18.6 mm Depth 0.732 in Pin spacing from 3.5 mm Pin spacing from 0.138 in Pollution degree 2 Measured voltage EN 160 V Measured shock voltage 2.5 kV Current intensity EN 10 A Pollution degree 2 1 von 4 Measured voltage EN 320 V Measured shock voltage 2.5 kV Current intensity EN 10 A 2 von 4 Data sheet from 15.07.2010 Connection method CAGE CLAMP® CONNECTION Cross section [mm²] 0.08 - 1.5 mm² Wiring method solid Cross section [mm²] 0.08 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [AWG] 28 - 14 AWG Strip length from 6 mm Strip length to 7 mm Material group I xxx-xxx/032-000 Strain relief plate 6 mm 3 von 4 Data sheet from 15.07.2010 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 734-104 ABS 04-HG469925/1-PDA 250 10 0,5-1,5 734-104 BV 11915/A0 250 10 0,5-1,5 734-104 CCA NL5641 250 10 0,5-1,5 734-104 CSA 154112-1465035 300 10 28-14 734-104 DNV E-9218 250 10 0,5-1,5 734-104 GL 17296-00HH 250 10 0,5-1,5 734-104 KEMA 2077592.02 250 10 0,5-1,5 734-104 LR 96/20035 250 10 0,5-1,5 734-104 RMR 11130002 250 10 0,5-1,5 734-104 UR E45171 250 10 28-14 734-104 UR E45172 300 10/10 28-14 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
734-104 价格&库存
很抱歉,暂时无法提供与“734-104”相匹配的价格&库存,您可以联系我们找货
    • 100+10.43160
    库存:1075
