Data sheet | Item number: 734-134
THT male header; 1.0 x 1.0 mm solder pin; straight; 100% protected against
mismating; Pin spacing 3.5 mm; 4-pole; light gray
www.wago.com/734-134
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
L = (pole no. – 1) x pin spacing + 5.9 mm
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
100 % protected against mismating; only mating halves with the same number of poles can be connected together
Coding via coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
160 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
320 V
Rated impulse voltage (II / 2)
Subject to changes.
Hansastr. 27
32423 Minden
2.5 kV
29.12.2019 Page 2/7
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
No. of poles
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
3.5 mm / 0.138 inch
Width
16.4 mm / 0.646 inch
Height
14.8 mm / 0.583 inch
Height from the surface
10.3 mm / 0.406 inch
Depth
8.5 mm / 0.335 inch
Solder pin length
4.5 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter (tolerance)
1.4(- … +0.1) mm
Plug connection
Contact type (pluggable connector)
Male connector/plug
Connector connection type
for PCBs
Mismating protection
Yes
Mating direction to the PCB
Subject to changes.
Hansastr. 27
32423 Minden
90 °
29.12.2019 Page 3/7
90 °
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire male connector, in line
Number of solder pins per potential
1
Material Data
Color
light gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.017 MJ
Weight
1 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918847568
Customs Tariff No.
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 61984
nl-54190
CCA
EN 61984
2169534.02
C22.2
1465035
CSA
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/7
CSA
C22.2
1465035
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
LR
Lloyds Register
IEC 61984
96/20035
(E5)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Certificate
name
Approval
UL
UL International Germany GmbH
UL 1977
20150318E45171
UR
Underwriters Laboratories Inc.
UL 1059
20190122E45172
Compatible products
Coding
Item no.: 734-130
Coding key; to be snapped above top level; white
www.wago.com/734-130
Item no.: 734-159
Coding key; to be snapped above top level; black
www.wago.com/734-159
Downloads
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 734-134
CAE data
EPLAN Data Portal 734-134
Download
PCB Design
Symbol and Footprint 734-134
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Coding
Coding a male header – fitting coding key(s).
Product family
MCS MINI
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
很抱歉,暂时无法提供与“734-134”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.99740
- 200+3.59810
- 400+3.59700
- 国内价格 香港价格
- 1+19.710001+2.55479
- 10+16.7960610+2.17709
- 100+15.20760100+1.97120
- 500+10.00718500+1.29712
- 1000+9.721351000+1.26008
- 5000+9.203045000+1.19289
- 国内价格
- 1+7.11720
- 10+5.61600
- 30+4.87080
- 200+4.13640
- 400+3.69360
- 国内价格 香港价格
- 8+20.104288+2.60590
- 10+17.1320010+2.22064
- 100+15.51154100+2.01059
- 500+10.20684500+1.32300
- 1000+9.916021000+1.28531
- 5000+9.387055000+1.21674
