7
SFP Modules 100Base-FX LC
536
ELECTRICAL SUBASSEMBLY
DATA
LASER
DATA/
TX_DISABLE
TX_FAULT
(0)
TX
< 6,25 >
RX
(1)
(2)
MOD_DEF
DATA
DATA/
RX_LOS
OPTICAL
SUBASSEMBLIES
PREAMPLIFIER
IC
Diode
ETHERNET via fiber optic cables offers a multitude of advantages for industrial applications.
High immunity to interference, electrical isolation, and long ranges are important parameters here.
Description
Item No.
Pack. Unit
SFP Module 2: 1310nm, 100Base-FX
Multi-mode LC, 2 km
Connector Duplex LC,
Wavelength 1310 nm,
Fiber type Multi-mode 62.5/125 μm, 50/125 μm,
Maximum length 2000 m,
Operating temperature 0 °C ... +60 °C,
Storage temperature -20 °C ... +80 °C,
Dimensions (mm) W x H x D: 13.4 x 13.3 x 56.6;
Laser Class 1 acc. to EN 60825-1
852-201/107-002
1
SFP Module 30: 1310nm, 100Base-FX
Single-mode LC, 30 km
Wavelength 1310 nm,
Fiber type Single-mode 9/125 μm,
Maximum length 30000 m,
852-201/107-030
1
SFP Module 2 T: 1310nm,
100Base-FX, Multi-mode, LC, 2 km,
(Extended temperature range: -40 °C ... +70 °C)
Wavelength 1310 nm,
Operating temperature -40 °C ... +70 °C,
Storage temperature -40 °C ... +80 °C,
852-201/040-002
1
Characteristics:
• Duplex LC optical connector
• Industry standard small form pluggable (SFP) package
• Compliant with Fast ETHERNET standard;
• Differential LVPECL inputs and outputs;
• Single 3.3V power supply;
• TTL signal detect indicator;
• Hot pluggable capability
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
26.01.2016
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
很抱歉,暂时无法提供与“852-201/107-002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1865.779981+242.35536
- 10+1795.7300510+233.25623
