855-305/600-509
855-305/600-509
    WAGO(万可电子)
    WAGO - 855-305/600-509 - Current Transformer, Pluggable, 600:5, Class 0.5, 5 VA, 26 mm, 50Hz / 60Hz
855-305/600-509 数据手册
Data sheet | Item number: 879-3040  ANNOUNCED Energy consumption meter; for transformer connection; 6 A; 3x230/400V; 50Hz; MID; Modbus® & M-Bus; 2 x S0 interface; 2CT www.wago.com/879-3040 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 1/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 X Attention: Product details may be subject to change Item description Short description: Comprehensive energy measurement is necessary for optimizing energy consumption. WAGO now has new energy meters in its portfolio that simplify this task while providing several key advantages. They use the push-in connection technology with a lever, making them connect quickly and easily. Versions for current transformers are even slimmer at only 35 mm. These widths save a tremendous amount of control cabinet space. In addition to the values for active and reactive energy, the energy meters also record the mains frequency as well as current, voltage and power for all phases. And the user can conveniently see all of these energy characteristics at a glance on a large, illuminated display. Features: Saving time at every level thanks to the Push-in CAGE CLAMP® and lever Real space savings: 35 mm wide (2PCT) Measurement of delivery and purchase Energy recording via 4 rates The communications pro: M-Bus and Modbus® interface and 2 S0 pulse outputs Full transparency at a glance: Display energy quality characteristics on an illuminated full-format display Intuitive configuration: Touch-sensitive controls and configuration app via Bluetooth® Data Technical data Configuration Configuration options Touch-sensitive controls Configuration app via Bluetooth® Input Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 2/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 Input Input signal type Voltage Current Network configuration Two-wire, three-wire and four-wire networks Nominal input voltage Ui nom 3 x (3) x AC 230 … 400 V Input voltage range ±20 % Reference current Iref 1  A Input current Ii ≤ 6 A Current transformer (secondary) 1  A 5  A Min. current transformer ratio 1 Max. current transformer ratio 9,999 Frequency range 45 … 65 Hz Communication Communication Modbus® M-Bus Bluetooth® Interface RS-485 (2-wire); 2x S0 interfaces (configurable) Rate control input AC/DC 230 V Indicators LCD with backlight Signal processing Measured variables (calculated) Active and reactive energy in supply and reference direction Messungsart (Lastgang) No Measurement error Accuracy class Class B (= 1 % error); Active energy per EN 50470-3 Calibration validity period 8 years Supply Power supply type Via measurement circuit Power consumption Pmax (phase; effective power) 2  W Power consumption Pmax (phase; apparent power) 10 VA Safety and protection Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 3/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 Safety and protection Dielectric strength 4 kV; 1 min Impulse withstand voltage (1.2/50 μs) 6 kV Pollution degree 2 Protection type IP51 (front side); IP20 (connection) Protection class II Connection data Connection type (1) Voltage/current Connection technology Push-in CAGE CLAMP® WAGO Connector WAGO 2604 Series Actuation type Lever Solid conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 2.5 mm² Strip length 9 … 11 mm / 0.35 … 0.43 inch Connection type 2 Communication/rate control input Connection technology 2 Push-in CAGE CLAMP® WAGO Connector 2 WAGO 857 Series Actuation type 2 Lever Solid conductor 2 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor 2 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor; with insulated ferrule 2 0.25 … 2.5 mm² / Fine-stranded conductor; with uninsulated ferrule 2 0.25 … 2.5 mm² / Strip length 2 9 … 11 mm / 0.35 … 0.43 inch Physical data Width 36 mm / 1.417 inch Height 140 mm / 5.512 inch Depth 63 mm / 2.48 inch Note (dimensions) Height without cover: 98.2 mm Mechanical data Mounting type DIN-35 rail Material Subject to data changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 4/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 Material data Housing material PC 940A Weight 165 g Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Relative humidity  75% (during storage 95 %) Standards and specifications Conformity marking CE Standards/Specifications EN 50470-1/3 MID-compliant Commercial data PU (SPU) 1 Stück Packaging type box Country of origin CN GTIN 4055144124675 Customs tariff number 90283019000 Optional accessories Current transformers Item no.: 855-305/100-209 Plug-in current transformer; Primary rated current: 100 A; Secondary rated current: 5 A; Rated power: 2.5 VA; Accuracy class: 0.5; for billing purposes www.wago.com/855-305 /100-209 Item no.: 855-305/150-209 Plug-in current transformer; Primary rated current: 150 A; Secondary rated current: 5 A; Rated power: 2.5 VA; Accuracy class: 0.5; for billing purposes www.wago.com/855-305 /150-209 Item no.: 855-305/200-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current: 200 A; Secondary rated current: 5 A; Rated power: 5 /200-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/250-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current: 250 A; Secondary rated current: 5 A; Rated power: 5 /250-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/300-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current 300 A; Secondary rated current: 5 A; Rated power: 5 /300-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/400-509 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/855-305 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 5/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 Item no.: 855-305/400-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 5 A; Rated power: 5 /400-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/500-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current: 500 A; Secondary rated current: 5 A; Rated power: 5 /500-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/600-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current: 600 A; Secondary rated current: 5 A; Rated power: 5 /600-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-305/750-509 www.wago.com/855-305 Plug-in current transformer; Primary rated current 750 A; Secondary rated current: 5 A; Rated power: 5 /750-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-405/200-209 Plug-in current transformer; Primary rated current: 200 A; Secondary rated current: 5 A; Rated power: 2.5 VA; Accuracy class: 0.5; for billing purposes www.wago.com/855-405 /200-209 Item no.: 855-405/250-209 Plug-in current transformer; Primary rated current: 250 A; Secondary rated current: 5 A; Rated power: 2.5 VA; Accuracy class: 0.5; for billing purposes www.wago.com/855-405 /250-209 Item no.: 855-405/300-509 www.wago.com/855-405 Plug-in current transformer; Primary rated current 300 A; Secondary rated current: 5 A; Rated power: 5 /300-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-405/400-509 www.wago.com/855-405 Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 5 A; Rated power: 5 /400-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-405/500-509 www.wago.com/855-405 Plug-in current transformer; Primary rated current: 500 A; Secondary rated current: 5 A; Rated power: 5 /500-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-405/600-509 www.wago.com/855-405 Plug-in current transformer; Primary rated current: 600 A; Secondary rated current: 5 A; Rated power: 5 /600-509 VA; Accuracy class: 0.5; for billing purposes Item no.: 855-405/750-509 www.wago.com/855-405 Plug-in current transformer; Primary rated current 750 A; Secondary rated current: 5 A; Rated power: 5 /750-509 VA; Accuracy class: 0.5; for billing purposes Downloads Documentation Instruction Leaflet Energy consumption meter V 1.12 2 Mar 2021 pdf 915.0 kB Download Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 6/7 Data sheet | Item number: 879-3040  ANNOUNCED www.wago.com/879-3040 CAD/CAE-Data CAD data 2D/3D Models 879-3040 URL Download URL Download CAE data ZUKEN Portal 879-3040 Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 7/7
855-305/600-509 价格&库存
很抱歉,暂时无法提供与“855-305/600-509”相匹配的价格&库存,您可以联系我们找货
