855-8004
855-8004
    WAGO(万可电子)
    WAGO - 855-8004 - Power Tap, 2 A, 400 VAC, 8-6 AWG, 855 Series
855-8004 数据手册
Data sheet | Item number: 855-8004 Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor www.wago.com/855-8004 Item description Short description: These voltage taps (855 Series) easily and safely tap the measurement voltage. This allows a fuse-protected measurement voltage to be tapped from an insulated conductor with just one turn – no tools required. Features: Safely tap the measurement voltage with just one turn Tool-free assembly Secure mounting Voltage taps (855-8001 and 855-8003) include a (5 x 25) mm 2 A fuse For insulated conductors up to 16 mm² (6 AWG) Cable length: 3 m Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 1/5 Data sheet | Item number: 855-8004 www.wago.com/855-8004 Data Technical data Output – voltage tap Rated voltage AC 400 V Continuous current (max.) 2  A Voltage drop at output (max.) ≤ AC 0.5 V Fuse (voltage path) - Safety and protection Rated surge voltage 6 kV Overvoltage category III Pollution degree 2 Protection type IP20 Test voltage Test voltage AC 3 kV; 50 Hz; 1 min Connection data Connection technology IDC Solid conductor 10 … 16 mm² / 8 … 6 AWG Fine-stranded conductor 10 … 16 mm² / 8 … 6 AWG Feedthrough for measurement conductor Ø 5 … 7 mm Cable type Secondary side: 1 x 1.0 mm²; flexible; with ferrule Physical data Width 23 mm / 0.906 inch Height 50 mm / 1.969 inch Depth 23 mm / 0.906 inch Cable length 3  m Mechanical data Mounting type Insulation displacement connection (IDC) Mounting type Mounting on insulated round cable Usability Can be reused several times (max. 24 times) Material data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 2/5 Data sheet | Item number: 855-8004 www.wago.com/855-8004 Material data Flammability class per UL94 V2 Housing material PA 66 Weight 21 g Environmental requirements Pollution degree 2 Surrounding air temperature (operation) -5 … 55 °C Surrounding air temperature (storage) -20 … 70 °C Relative humidity 5 … 85 % (without condensation) Operating altitude (max.) 2000 m Standards and specifications Conformity marking CE Standards/Specifications EN 60947-7-1 Commercial data PU (SPU) 10 (1) Stück Packaging type box Country of origin NL GTIN 4055143378840 Customs tariff number 85366990990 Optional accessories General accessories Item no.: 2007-8873 Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured www.wago.com/2007-8873 Item no.: 2007-8874 Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured www.wago.com/2007-8874 Item no.: 2007-8875 Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8875 Item no.: 2007-8876 Compact terminal block; for 3-phase current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8876 Item no.: 2007-8877 Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8877 Item no.: 2857-570/024-000 3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via www.wago.com/2857-570 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 3/5 Data sheet | Item number: 855-8004 www.wago.com/855-8004 Item no.: 2857-570/024-000 3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via www.wago.com/2857-570 software; Supply voltage: 24 VDC /024-000 Item no.: 2857-570/024-001 www.wago.com/2857-570 3-Phase Power Measurement Module; 3x400/690 V/1 A; Modbus RTU; Digital output; Configuration via /024-001 software; Supply voltage: 24 VDC Item no.: 2857-570/024-005 www.wago.com/2857-570 3-Phase Power Measurement Module; 3x400/690 V/5 A; Modbus RTU; Digital output; Configuration via /024-005 software; Supply voltage: 24 VDC Item no.: 857-560 Voltage signal conditioner; Voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC; 6 mm module width www.wago.com/857-560 Item no.: 857-569 Power signal conditioner; Current and voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC; 6 mm module width www.wago.com/857-569 Downloads Documentation Bid Text 855-8004 20 Feb 2019 docx 17.6 kB Download 19 Feb 2019 xml 5.1 kB Download pdf 79.6 kB Download pdf 265.8 kB Download URL Download docx - Datei 855-8004 X81 - Datei Instruction Leaflet Potentialabgriffe Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 Environmental Product Compliance Compliance Search Environmental Product Compliance 855-8004 Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 4/5 Data sheet | Item number: 855-8004 www.wago.com/855-8004 Installation Notes Installation Installation on an insulated conductor with insulation displacement connection (IDC) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 04.08.2021    Page 5/5
855-8004 价格&库存
很抱歉,暂时无法提供与“855-8004”相匹配的价格&库存,您可以联系我们找货
