857-152
857-152
    WAGO(万可电子)
    插件
857-152 数据手册
Data sheet  |  Item number: 857-152 Basic relay; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 6 A; Module width: 5 mm; Module height: 15 mm www.wago.com/857-152 Similiar to picture Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 1/5 Data sheet  |  Item number: 857-152 www.wago.com/857-152 DC load limit curve Item description Note: The 60 VDC bsic relay must be used for 60 VDC, 110 VDC, 220 VDC and 115 VAC/DC, 230 VAC/DC relay modules. Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. In the case of gold-plated bsic relays switching voltages of 30 VDC and currents of 50 mA should not be exceeded. Higher switching power eventually evaporates the gold layer. The resulting deposits in the housing may reduce the service life. Data Technical Data Control circuit Nominal input voltage UN DC 24 V Load circuit: Number of changeover/switchover contacts 1 Contact material (relay) AgSnO2 Limiting continuous current 6 A Max. make current (resistive) (AC) 20 A / 0.02 s Max. switching voltage AC 250 V Max. switching power (resistive) AC 1500 VA; DC see load limit curve Switching capacity AC-15: 3 A / AC 250 V; DC-13: 2 A / DC 24 V Recommended minimum load Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 10 V / 10 mA; 24 V / 1 mA Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 2/5 Data sheet  |  Item number: 857-152 www.wago.com/857-152 Recommended minimum load 10 V / 10 mA; 24 V / 1 mA Pull-in time (typ.) 8 ms Drop-out time (typ.) 4 ms Bounce time (typ) 3.5 ms Electrical life (N.O.; resistive load; 23 °C) 50 x 103 switching operations Mechanical life 5 x 106 switching operations Max. switching load with load/without load 6 min-1 / 180 min-1 Safety and protection: Dielectric strength, control/load circuit (AC, 1 min) 4 kVrms Dielectric strength open contact (AC, 1 min) 1 kVrms Protection class IP20 Geometrical Data Width 5 mm / 0.197 inch Height from the surface 15 mm / 0.591 inch Depth 28 mm / 1.09 inch Mechanical data Type of mounting Pluggable module Material Data Weight 6.5 g Environmental Requirements Surrounding air (operating) temperature at UN -40 … 85 °C Surrounding air (storage) temperature -40 … 85 °C Standards and specifications Standards/specifications EN 61810-1, EN 61373; VDE, UR Commercial data Product Group 6 (Interface Electronics) Packaging type BOX Country of origin Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com DE Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 3/5 Data sheet  |  Item number: 857-152 www.wago.com/857-152 Country of origin DE GTIN 4045454550998 Customs Tariff No. 85364900990 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 508 E340707 Compatible products General accessories Item no.: 857-104 Relay socket; Nominal input voltage: 24 V AC/DC; for 5 mm basic relays; Yellow status indicator www.wago.com/857-104 Downloads Documentation Bid Text 857-152 Feb 19, 2019 xml 4.3 kB Download Nov 29, 2018 doc 27.1 kB Download V 1.0.0 pdf 265.8 kB Download X81 - Datei 857-152 doc - Datei Additional Information Disposal; Electrical and electronic equipment, Packaging CAD/CAE-Data CAE data EPLAN Data Portal 857-152 Download WSCADto Universe 857-152 Subject changes. Download WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 4/5 Data sheet  |  Item number: 857-152 www.wago.com/857-152 WSCAD Universe 857-152 Download Installation Notes Assembly Operation of the relay ejector Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 5/5
857-152 价格&库存
很抱歉,暂时无法提供与“857-152”相匹配的价格&库存,您可以联系我们找货
