2002-0991
2002-0991
    WAGO(万可电子)
    WAGO - 2002-0991 - END PLATE, TOPJOB TERMINAL BLOCK
2002-0991 数据手册
Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-991 . End plate for fuse terminal blocks; 2 mm thick Item No.: 2002-991 . End plate for fuse terminal blocks; 2 mm thick . Marking . Business data Supplier WAGO Item no. 2002-991 GTIN / EAN 4045454779238 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Color gray Fire load [MJ] 0.107 [MJ] Weight [g] 3.82 [g] Width 2 mm / 0.079 in Height from upper-edge of DIN-rail [mm] 57.2 [mm] Height from upper-edge of DIN-rail 57.2 mm / 2.252 in Length 67 mm / 2.638 in WAGO Kontakttechnik GmbH & Co. KG 1 Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-991 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 2 Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-991 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
2002-0991 价格&库存
很抱歉,暂时无法提供与“2002-0991”相匹配的价格&库存,您可以联系我们找货
