2002-2231
2002-2231
    WAGO(万可电子)
2002-2231 数据手册
TOPJOB® S Double-Deck Terminal Blocks 2.5 (4) mm² 2002 Series 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 69,7 mm/2.74 in 51,7 mm/2.03 in 61,8 mm/2.43 in 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) 51,7 mm/2.03 in 61,8 mm/2.43 in 28 51,7 mm/2.03 in 61,8 mm/2.43 in 1 69,7 mm/2.74 in Pack. Unit Item No. Through/through terminal block, with marker carrier, gray housing 2002-2231 5 L/L 4 2002-2232 5 N/L 4 2002-2233 5 L/N 4 Pack. Unit Item No. Through/through terminal block, with marker carrier, blue housing 2002-2234 4 5 N/N 4 50 50 50 Through/through terminal block, without marker carrier, gray housing 2002-2201 5 L/L 4 2002-2202 5 N/L 4 2002-2203 5 L/N 4 69,7 mm/2.74 in Through/through terminal block, without marker carrier, blue housing 2002-2204 4 5 N/N 4 50 50 50 Pack. Unit Item No. Ground conductor/through terminal block, with marker carrier, gray housing 50 2002-2247 5 PE/N 4 50 2002-2257 5 PE/L 4 50 Ground conductor/through terminal block, without marker carrier, gray housing 50 2002-2217 5 PE/N 4 50 2002-2227 5 PE/L 4 50 69,7 mm/2.74 in   Item No. 3 69,7 mm/2.74 in Pack. Unit   Item No. 69,7 mm/2.74 in Pack. Unit   Item No. 4-conductor through terminal block, with marker carrier, internal commoning, conductor entry position colored in violet, gray housing 50 2002-2238 5 L4 4-conductor through terminal block, with marker carrier, internal commoning, conductor entry position colored in violet, blue housing 50 2002-2239 4 5 N4 4-conductor ground terminal block, with marker carrier, internal commoning, green-yellow housing 4-conductor through terminal block, without marker carrier, internal commoning, conductor entry position colored in violet, gray housing 50 2002-2208 5 L4 4-conductor through terminal block, without marker carrier, internal commoning, conductor entry position colored in violet, blue housing 50 2002-2209 4 5 N4 4-conductor ground terminal block, without marker carrier, internal commoning, green-yellow housing Certification organizations can be found in the overview on page 622. 51,7 mm/2.03 in 61,8 mm/2.43 in 2 51,7 mm/2.03 in 61,8 mm/2.43 in 1 51,7 mm/2.03 in 61,8 mm/2.43 in Other terminal blocks with the same profile: 2002-2211/1000-410 Page86 Diode 2002-2221/1000-434 Page86 LED PE 4 PE 4 2002-2237 5 2002-2207 5 Pack. Unit 50 50
2002-2231 价格&库存
很抱歉,暂时无法提供与“2002-2231”相匹配的价格&库存,您可以联系我们找货
    • 50+10.04796
    库存:58
    2002-2231
    • 1+80.688531+10.43830
    • 10+57.2390610+7.40475
    • 25+50.4967125+6.53252
    • 50+46.3856250+6.00069
    • 100+43.04163100+5.56810
    • 250+39.62442250+5.12603
    • 500+37.66202500+4.87216
    • 1000+36.127221000+4.67361
    库存:1142
