Printview: Triple-deck terminal block; Through/through/through terminal block; L/L/L; with marker carrier;
gray housing; suitable for Ex e II applications - Item No.: 2002-3231
block; L/L/L; with marker carrier; gray housing; suitable for Ex e II
applications
Item No.: 2002-3231
Triple-deck terminal block; Through/through/through terminal block; L/L/L; with marker carrier; gray housing; suitable
Marking
Business data
Supplier
WAGO
Item no.
2002-3231
EAN
4044918989756
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
6
Total number of potentials
3
Number of levels
3
Color
gray
Pollution degree (1)
3
Rated voltage EN (1) [V]
500 [V]
Rated surge voltage (1) [kV]
6 [kV]
Nominal current [A]
24 [A]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Nominal current (2) [A]
28 [A]
Rated voltage EN (Ex e II) [V]
440 [V]
Nominal current (Ex e II) [A]
19 [A]
Nominal current with jumper [A]
17 [A]
Connection technology (1)
CAGE CLAMP® S
Connection type
CAGE CLAMP®
Conductor type (1)
solid + fine-stranded
Cross section from (1) [mm²]
0.25 [mm²]
Cross section up to (1) [mm²]
2.5 [mm²]
Cross section from (1) [AWG]
22 [AWG]
Cross section up to (1) [AWG]
12 [AWG]
Conductor type (2)
Cross section from (2) [mm²]
0.25 [mm²]
Cross section up to (2) [mm²]
4 [mm²]
Cross section from (2) [AWG]
22 [AWG]
Cross section up to (2) [AWG]
12 [AWG]
Stripped length from (1) [mm]
10 [mm]
Stripped length up to (1) [mm]
12 [mm]
Stripped length (1) [in]
0.43 [in]
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Fire load [MJ]
0.336 [MJ]
Weight [g]
17.528 [g]
Width [mm]
5.2 [mm]
Width [in]
0.205 [in]
Height [mm]
81.5 [mm]
Height [in]
3.209 [in]
Length [mm]
93.5 [mm]
Length [in]
3.681 [in]
Type of mounting
DIN 35 rail
2
Approbation
Item No.
Registration
Registration no.
Voltage [V]
Current [A]
Cross section
[mm², AWG]
2002-3231
AEX
E185892
550
2002-3231
ATEx
PTB 03 ATEX
1162 U
440
19
0.25-4.00
2002-3231
CCA
NL6387
500
24
0,2-2,5/4
2002-3231
CCA
NTR NL-7166
500
24
0.25-4.00
2002-3231
CSA
154112-1536069
600
2002-3231
GL
6187-05HH
500
24
4,0
2002-3231
KEMA
NL2116586.02
500
24
0,2-4
2002-3231
LR
91/20112(E6)
500
24
4,0
2002-3231
PTB
PTB03Atex1162U 440
19
0,2-4
2002-3231
PTB
IECExPTB03.000 440
4U
19
0,2-4
2002-3231
RosTest
8189158
440
19
0,2-4
2002-3231
UL
E45172
300
Accessories
Insulation stop
Item no.
Description
Pack. unit (Sub Pack)
2002-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip
25
2002-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
25
3
Accessories
Jumper
Item no.
Description
2002-402
Push-in type jumper bar; insulated; 2-way; nominal current 25 A
25
2002-403
Push-in type jumper bar; insulated; 3-way; nominal current 25 A
25
2002-404
Push-in type jumper bar; insulated; 4-way; nominal current 25 A
25
2002-405
Push-in type jumper bar; insulated; 5-way; nominal current 25 A
25
2002-405/011-000
Star point jumper; insulated; 1-3-5; IN = IN terminal block
25
2002-406
Push-in type jumper bar; insulated; 6-way; nominal current 25 A
25
2002-406/000-005
25
2002-406/000-006
25
2002-406/020-000
Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block
25
2002-407
Push-in type jumper bar; insulated; 7-way; nominal current 25 A
25
2002-408
Push-in type jumper bar; insulated; 8-way; nominal current 25 A
25
2002-409
Push-in type jumper bar; insulated; 9-way; nominal current 25 A
25
2002-410
Push-in type jumper bar; insulated; 10-way; nominal current 25 A
25
2002-410/000-005
25
2002-410/000-006
25
2002-433
Push-in type jumper bar; insulated; from 1 to 3; nominal current 25 A
25
2002-434
Push-in type jumper bar; insulated; from 1 to 4; nominal current 25 A
25
2002-435
Push-in type jumper bar; insulated; from 1 to 5; nominal current 25 A
25
2002-436
Push-in type jumper bar; insulated; from 1 to 6; nominal current 25 A
25
2002-437
Push-in type jumper bar; insulated; from 1 to 7; nominal current 25 A
25
2002-438
Push-in type jumper bar; insulated; from 1 to 8; nominal current 25 A
25
2002-439
Push-in type jumper bar; insulated; from 1 to 9; nominal current 25 A
25
2002-440
Push-in type jumper bar; insulated; from 1 to 10; nominal current 25 A
25
2002-472
Staggered jumper; insulated; 2-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
rail-mounted terminal blocks
2002-473
Staggered jumper; insulated; 3-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-473/011-000
Ready-made staggered jumper; insulated; 1-3; nominal current 25 A; with contact lugs
25
broken off at the factory and circuit marking
2002-474
Staggered jumper; insulated; 4-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
4
Accessories
2002-475
Staggered jumper; insulated; 5-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-475/011-000
Ready-made staggered jumper; insulated; 1-3-5; nominal current 25 A; with contact lugs
25
2002-476
Staggered jumper; insulated; 6-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-477
Staggered jumper; insulated; 7-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-477/011-000
Ready-made staggered jumper; insulated; 1-3-5-7; nominal current 25 A; with contact lugs
25
2002-478
Staggered jumper; insulated; 8-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-479
Staggered jumper; insulated; 9-way; nominal current 25 A; suitable for 2002 and 2003 Series 25
2002-479/011-000
Ready-made staggered jumper; insulated; 1-3-5-7-9; nominal current 25 A; with contact lugs 25
2002-480
Staggered jumper; insulated; 10-way; nominal current 25 A; suitable for 2002 and 2003
25
Series rail-mounted terminal blocks
2002-481
Staggered jumper; insulated; 11-way; nominal current 25 A; suitable for 2002 and 2003
25
2002-481/011-000
Ready-made staggered jumper; insulated; 1-3-5-7-9-11; nominal current 25 A; with contact
25
lugs broken off at the factory and circuit marking
2002-482
Staggered jumper; insulated; 12-way; nominal current 25 A; suitable for 2002 and 2003
25
2002-492
Double-deck vertical jumper; insulated
25
2002-493
Triple-deck vertical jumper; insulated
25
2009-412
Push-in type wire jumper; insulated; wire length 60 mm; conductor cross section 1.5 mm²;
10
suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks
2009-414
Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 1.5 mm²;
10
2009-416
Push-in type wire jumper; insulated; wire length 250 mm; conductor cross section 1.5 mm²;
10
210-103
Wire commoning chain; insulated; 50 connections
1
210-123
1
2002-402/000-005
25
5
Accessories
2002-402/000-006
25
2002-403/000-005
25
2002-403/000-006
25
2002-404/000-005
25
2002-408/000-006
25
2002-409/000-005
25
2002-409/000-006
25
2002-404/000-006
25
2002-405/000-005
25
2002-405/000-006
25
2002-407/000-005
25
2002-407/000-006
25
2002-408/000-005
25
End plate
Item no.
Description
2002-3291
End and intermediate plate; 0.8 mm thick
25
2002-3292
25
Carrier rail
Item no.
210-112
Description
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to en 60715; "Hole
1
width 25 mm
210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to en 60715
1
210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; according to en 60715
1
210-115
1
width 18 mm
210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to en 60715
210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; according to en 60715 1
210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; according to en 60715
1
210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to en 60715
1
6
1
Accessories
Marking accessories
Item no.
Description
2009-110
Marking strips; plain; 11 mm wide; 50m roll; for TOPJOB®S Series
1
2009-115
WMB Inline; plain; 1,500 WMB markers (5 mm) on roll; stretchable 5 - 5.2 mm
1
2009-135
WMB Inline; plain; 8,000 WMB markers (5 mm) on roll; stretchable 5 - 5.2 mm
1
2009-145
Mini-WSB Inline; plain; 1,700 Mini-WSB markers (5 mm) on roll; stretchable 5 - 5.2 mm
1
248-501
Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers
5
per card
248-501/000-002
5
per card
248-501/000-005
5
per card
248-501/000-006
5
per card
248-501/000-007
5
per card
248-501/000-012
5
per card
248-501/000-017
5
per card
248-501/000-023
5
per card
248-501/000-024
5
per card
793-501
WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10
5
markers per card
793-501/000-002
5
markers per card
793-501/000-005
5
markers per card
793-501/000-006
5
markers per card
793-501/000-007
markers per card
7
5
Accessories
793-501/000-012
5
markers per card
793-501/000-017
5
markers per card
793-501/000-023
5
markers per card
793-501/000-024
5
markers per card
793-5501
WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2
5
mm; 10 strips with 10 markers per card
793-5501/000-002
5
793-5501/000-005
5
793-5501/000-006
5
793-5501/000-007
5
793-5501/000-012
5
793-5501/000-017
5
793-5501/000-023
5
793-5501/000-024
5
Protective warning marker
Item no.
2002-115
Description
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks
8
25
Accessories
General accessory
Item no.
Description
2002-116
Multi-purpose operating tool; for component plugs
5
2009-191
TOPJOB®S group marker carrier; snap-on type for jumper slot; 5 mm wide
25
2009-192
TOPJOB®S group marker carrier; snap-on type for jumper slot; 10 mm wide
25
2009-193
TOPJOB®S group marker carrier; snap-on type for jumper slot; 15 mm wide
25
2002-400
Adjacent jumper for continuous commoning; insulated; 2-way; nominal current 25 A
25
9
Images & drawings
10
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
11
很抱歉,暂时无法提供与“2002-3231”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+121.995441+15.76573
- 10+86.7374910+11.20927
- 25+76.9387825+9.94296
- 50+71.0438550+9.18115
- 100+66.28593100+8.56627
- 250+61.45880250+7.94245
- 500+58.70272500+7.58628
- 1000+56.555671000+7.30881
