2003-7649
2003-7649
    WAGO(万可电子)
2003-7649 数据手册
Data sheet | Item number: 2003-7649 Multilevel installation terminal block; with operating slots; 2.5 mm²; N/L; Pushin CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2003-7649 Color: Data Electrical data Ratings per IEC/EN Nominal voltage (III/3) 400 V Rated surge voltage (III/3) 6 kV Rated current Subject to changes. Please also observe the further product documentation!24 A WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 1/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Rated surge voltage (III/3) 6 kV Rated current 24 A Rated current 2 32 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross-section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor; push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1 … 2.5 mm² / 18 … 14 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 10 … 12 mm / 0.39 … 0.47 inch Total number of connection points 4 Total number of potentials 2 Number of levels 2 Wiring type Front-entry wiring Physical data Width 5.2 mm / 0.205 inch Height 96 mm / 3.78 inch Depth from upper edge of DIN-rail 42.3 mm / 1.665 inch Mechanical data Potential marking N/L Design angled Mounting type DIN-35 rail Marking level Center/side marking Material data Color gray Insulation material Polyamide (PA66) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 2/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Insulation material Polyamide (PA66) Fire load 0.24 MJ Weight 13.6 g Commercial data Product Group 22 (TOPJOB S) Packaging type BOX Country of origin DE GTIN 4044918925624 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 71113530 CCA DEKRA Certification B.V. EN 60947 NTR NL7828 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) Required accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 3/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Required accessories End plate Item no.: 2003-7692 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2003-7692 Compatible products Push-In type wire jumper Item no.: 2009-412 Push-in type wire jumper; insulated; 60 mm long; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black www.wago.com/2009-414 Item no.: 2009-414/000-005 Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black www.wago.com/2009-414 /000-005 Item no.: 2009-414/000-006 Push-in type wire jumper; insulated; 110 mm long; black www.wago.com/2009-414 /000-006 Item no.: 2009-416 Push-in type wire jumper; 1.5 mm²; insulated; 250 mm long; black www.wago.com/2009-416 Insulation stop Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Item no.: 2009-309 Operating tool; Blades: 3.5 x 0.5 mm and 2.5 x 0.4 mm; for TOPJOB®S installation terminal blocks www.wago.com/2009-309 tools Item no.: 2009-310 www.wago.com/2009-310 Operating tool; Blades: 3.5 x 0.5 mm and 5.5 x 0.8 mm; for TOPJOB®S installation terminal blocks; green Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 check Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 4/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-145 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 5/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-198 Adaptor; gray www.wago.com/2009-198 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 6/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 7/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-014 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-014 type; brown Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-197 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 8/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 2009-304 Busbar carrier; not suitable for use as end stop; for DIN 35 rail; 1.5 mm thick; blue www.wago.com/2009-304 assembling Item no.: 2009-305 www.wago.com/2009-305 Busbar carrier; with end stop function and detachable separator plate; for DIN 35 rail; 7.5 mm thick; blue ferrule Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 2002-400 Continuous jumper; 2-way; insulated; light gray www.wago.com/2002-400 Item no.: 2002-402 Jumper; 2-way; insulated; light gray www.wago.com/2002-402 Jumper Item no.: 2002-402/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 9/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 2002-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2002-402 /000-005 Item no.: 2002-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2002-402 /000-006 Item no.: 2002-403 Jumper; 3-way; insulated; light gray www.wago.com/2002-403 Item no.: 2002-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2002-403 /000-005 Item no.: 2002-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2002-403 /000-006 Item no.: 2002-404 Jumper; 4-way; insulated; light gray www.wago.com/2002-404 Item no.: 2002-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2002-404 /000-005 Item no.: 2002-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2002-404 /000-006 Item no.: 2002-405 Jumper; 5-way; insulated; light gray www.wago.com/2002-405 Item no.: 2002-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2002-405 /000-005 Item no.: 2002-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2002-405 /000-006 Item no.: 2002-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2002-405 /011-000 Item no.: 2002-406 Jumper; 6-way; insulated; light gray www.wago.com/2002-406 Item no.: 2002-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2002-406 /000-005 Item no.: 2002-406/000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 10/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 2002-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2002-406 /000-006 Item no.: 2002-406/020-000 Delta jumper; insulated; light gray www.wago.com/2002-406 /020-000 Item no.: 2002-407 Jumper; 7-way; insulated; light gray www.wago.com/2002-407 Item no.: 2002-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2002-407 /000-005 Item no.: 2002-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2002-407 /000-006 Item no.: 2002-408 Jumper; 8-way; insulated; light gray www.wago.com/2002-408 Item no.: 2002-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2002-408 /000-005 Item no.: 2002-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2002-408 /000-006 Item no.: 2002-409 Jumper; 9-way; insulated; light gray www.wago.com/2002-409 Item no.: 2002-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2002-409 /000-005 Item no.: 2002-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2002-409 /000-006 Item no.: 2002-410 Jumper; 10-way; insulated; light gray www.wago.com/2002-410 Item no.: 2002-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2002-410 /000-005 Item no.: 2002-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2002-410 /000-006 Item no.: 2002-423 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-423 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 11/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 2002-423 Continuous jumper; from 1 to 3; insulated; light gray www.wago.com/2002-423 Item no.: 2002-423/000-005 Continuous jumper; from 1 to 3; insulated; red www.wago.com/2002-423 /000-005 Item no.: 2002-423/000-006 Continuous jumper; from 1 to 3; insulated; blue www.wago.com/2002-423 /000-006 Item no.: 2002-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2002-433 Item no.: 2002-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2002-434 Item no.: 2002-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2002-435 Item no.: 2002-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2002-436 Item no.: 2002-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2002-437 Item no.: 2002-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2002-438 Item no.: 2002-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2002-439 Item no.: 2002-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2002-440 Item no.: 2002-472 Staggered jumper; 2-way; insulated; light gray www.wago.com/2002-472 Item no.: 2002-473 Staggered jumper; 3-way; insulated; light gray www.wago.com/2002-473 Item no.: 2002-473/011-000 Staggered jumper; 2-way; from 1 to 3; insulated; light gray www.wago.com/2002-473 /011-000 Item no.: 2002-474 Staggered jumper; 4-way; insulated; light gray www.wago.com/2002-474 Item no.: 2002-475 Staggered jumper; 5-way; insulated; light gray www.wago.com/2002-475 Item no.: 2002-475/011-000 Staggered jumper; 3-way; insulated; light gray www.wago.com/2002-475 /011-000 Item no.: 2002-476 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 12/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Item no.: 2002-476 Staggered jumper; 6-way; insulated; light gray www.wago.com/2002-476 Item no.: 2002-477 Staggered jumper; 7-way; insulated; light gray www.wago.com/2002-477 Item no.: 2002-477/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-477 /011-000 Item no.: 2002-478 Staggered jumper; 8-way; insulated; light gray www.wago.com/2002-478 Item no.: 2002-479 Staggered jumper; 9-way; insulated; light gray www.wago.com/2002-479 Item no.: 2002-479/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-479 /011-000 Item no.: 2002-480 Staggered jumper; 10-way; insulated; light gray www.wago.com/2002-480 Item no.: 2002-481 Staggered jumper; 11-way; insulated; light gray www.wago.com/2002-481 Item no.: 2002-481/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-481 /011-000 Item no.: 2002-482 Staggered jumper; 12-way; insulated; light gray www.wago.com/2002-482 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Downloads Documentation Bid Text 2003-7649 2019 Apr 29 xml 4.0 kB Download 2019 Apr 29 docx 15.2 kB Download 2019 Apr 3 pdf Download X81 - Datei 2003-7649 docx - Datei Additional Information Technical explanations Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 13/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Additional Information Technical explanations 2019 Apr 3 pdf 2.2 MB Download URL Download EPLAN Data Portal 2003-7649 URL Download WSCAD Universe 2003-7649 URL Download ZUKEN Portal 2003-7649 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2003-7649 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2003-7649 Multilevel installation terminal block; with operating slots; 2.5 mm²; N/L; Push-in CAGE CLAMP®; 2,50 mm²; gray Installation Notes Conductor termination All conductor types at a glance Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 14/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Inserting a conductor via push-in termination. Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Inserting a conductor via operating tool. Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. Commoning Adjacent Jumpers for Continuous Commoning (2002‑400) Commoning two potentials in one single jumper slot via extremely slim staggered jumpers. Removing a staggered jumper: Insert the operating tool between the staggered jumpers, then lift up the jumper. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 15/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 Orient the staggered jumpers' red stripes on the inside. Orient the staggered jumpers' red stripes on the inside. Insert the staggered jumper and push down until it hits the backstop. Insert the staggered jumper and push down until it hits the backstop. Mounting busbars on busbar carriers: Insert busbar ends onto large busbar carriers (2009‑305) or onto supply terminal blocks with an integrated busbar carrier. The busbar transparent cover (Item No. 777303) protects the busbar against accidental contact and makes it easy to see which terminal blocks are connected to the busbar. Product family TOPJOB® S TOPJOB® S: In various applications and modern building installations, WAGO's wide and versatile range of railSubject to changes. Please also observe the furtherindustrial product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 16/17 Data sheet | Item number: 2003-7649 www.wago.com/2003-7649 TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 17/17
2003-7649 价格&库存
很抱歉,暂时无法提供与“2003-7649”相匹配的价格&库存,您可以联系我们找货
  • 40+22.46509
库存:30
