2042-3074
2042-3074
    WAGO(万可电子)
    SOCKETABLE
    REL
2042-3074 数据手册
Data sheet  |  Item number: 2042-3074 Relay module; Relay with 3 make contacts and 1 break contact (3a1r); 24 VDC; Path www.wago.com/2042-3074 Similiar to picture 03.04.2019    Page 1/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 DC load limit curve Data Technical Data Control circuit Nominal input voltage UN DC 24 V Input voltage range -30 … +25 % Nominal input current at UN 27.4 mA Load circuit: Number of break contacts/switch off contacts 1 Number of make contacts/switch on contacts 3 Contact material (relay) AgNi Limiting continuous current 5 A Max. make current (resistive) (AC) 15 A / 4 s Max. switching voltage AC 250 V Max. switching power (resistive) AC 1,250 VA; DC see load limit curve Recommended minimum load 12 V / 10 mA Min. switching current 0 µA Pull-in time (typ.) 8 ms Drop-out time (typ.) 6 ms Bounce time (typ) 4 ms Drop-out time ≤ 0 µs Electrical life (N.O.; resistive load; 23 °C) 100 x 103 switching operations Mechanical life (N.O.; resistive load; 23 °C) 10 x 106 switching operations Signaling 03.04.2019    Page 2/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 Signaling Status indication LED green Safety and protection: Rated voltage 250 V Rated impulse voltage 4 kV Pollution degree 2 Dielectric strength, control/load circuit (AC, 1 min) 3 kVrms Dielectric strength open contact (AC, 1 min) 1 kVrms Dielectric strength, channel/channel (AC, 1 min) 2.5 kVrms Protection class IP20 Geometrical Data Width 25.9 mm / 1.02 inch Height 77.7 mm / 3.059 inch Height from the surface 59.3 mm / 2.335 inch Depth 52 mm / 2.047 inch Mechanical data Type of mounting Pluggable module for TOPJOB® S carrier terminal block Material Data Flammability class per UL94 V0 Fire load 0.269 MJ Weight 58.7 Environmental Requirements Pollution degree 2 Surrounding air (operating) temperature at UN -40 … 70 °C Surrounding air (storage) temperature -40 … 85 °C Max. operating altitude 2000 m Standards and specifications Standards/specifications EN 61010-2-201; EN 61373; EN 50121-3-2 Commercial data Country of origin DE GTIN 4055143606820 03.04.2019    Page 3/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 GTIN 4055143606820 Compatible products Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 03.04.2019    Page 4/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-014 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-014 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-024 03.04.2019    Page 5/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 Terminal Block Item no.: 2002-1661 Carrier terminal block; for disconnect; fuse or component plug; rail mount; 2-conductor; 5.2 mm wide; gray www.wago.com/2002-1661 Item no.: 2002-1761 Carrier terminal block; for disconnect; fuse or component plug; rail mount; 3-conductor; 5.2 mm wide; gray www.wago.com/2002-1761 Item no.: 2002-1861 Carrier terminal block; for disconnect; fuse or component plug; rail mount; 4-conductor; 5.2 mm wide; gray www.wago.com/2002-1861 Item no.: 2002-1961 Carrier terminal block; for disconnect; fuse or component plug; with additional jumper location; rail mount; 2-conductor; 5.2 mm wide; gray www.wago.com/2002-1961 Item no.: 2002-1691 TOPJOB®S end/intermediate plate; for 2002-16xx series terminal blocks; 1.0 mm wide; gray www.wago.com/2002-1691 Item no.: 2002-1692 TOPJOB®S end/intermediate plate; for 2002-16xx series terminal blocks; 1.0 mm wide; orange www.wago.com/2002-1692 Item no.: 2002-1791 TOPJOB®S end/intermediate plate; for 2002-17xx series terminal blocks; 1.0 mm wide; gray www.wago.com/2002-1791 Item no.: 2002-1792 TOPJOB®S end/intermediate plate; for 2002-17xx series terminal blocks; 1.0 mm wide; orange www.wago.com/2002-1792 Item no.: 2002-1891 TOPJOB®S end/intermediate plate; for 2002-18xx series terminal blocks; 1.0 mm wide; gray www.wago.com/2002-1891 Item no.: 2002-1892 TOPJOB®S end/intermediate plate; for 2002-18xx series terminal blocks; 1.0 mm wide; orange www.wago.com/2002-1892 End plate Downloads Documentation Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 10-Oct-2018 pdf 265.8 kB Download URL Download CAD files CAD data 3D Download 2042-3074   03.04.2019    Page 6/7 Data sheet  |  Item number: 2042-3074 www.wago.com/2042-3074 Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at {0}. 03.04.2019    Page 7/7
2042-3074 价格&库存
很抱歉,暂时无法提供与“2042-3074”相匹配的价格&库存,您可以联系我们找货
