2061-1603/998-404
2061-1603/998-404
    WAGO(万可电子)
    插件
    接线端子 每排针脚数:3 排数:单排
2061-1603/998-404 数据手册
Data sheet  |  Item number: 2061-1603/998-404 THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging; 1,50 mm2; white www.wago.com/2061-1603/998-404 Color: 24.09.2019    Page 1/6 Data sheet  |  Item number: 2061-1603/998-404 www.wago.com/2061-1603/998-404 Item description THR PCB terminal blocks with push-buttons and Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Push-buttons simplify insertion/removal of all conductor types Just 5.6 mm tall Available in tape-and-reel packaging for automated assembly Also suitable for wave soldering Assemble terminal blocks without pole loss Note: Application note: Suitable for lead-free, reflow-soldering profiles per DIN EN 61760-1 and IEC 60068-2-58 up to max. 260 °C peak temperature. Due to customer-specific variables (e.g., component configuration and orientation, type of soldering machine, solder paste), trial runs are recommended to ensure product and process compatibility under actual manufacturing conditions. Recommendation: Recommendation for stencil: 150 µm material thickness The stencil hole diameter is identical to the outer diameter of the metal-plated PCB hole. Data Electrical data Ratings per IEC/EN 60664-1 24.09.2019    Page 2/6 Data sheet  |  Item number: 2061-1603/998-404 www.wago.com/2061-1603/998-404 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 17.5 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor with ferrule with plastic collar 0.5 … 0.75 mm² Fine-stranded conductor with ferrule without plastic collar 0.5 … 0.75 mm² Strip length 7 … 10 mm / 0.28 … 0.39 inch Conductor entry angle to the PCB 0  ° Total number of connection points 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 No. of poles 3 Geometrical Data Pin spacing 6 mm / 0.24 inch Width 17.7 mm / 0.697 inch Height 8 mm / 0.315 inch Height from the surface 5.6 mm / 0.22 inch Depth 15.2 mm / 0.598 inch Solder pin length 2.4 mm Solder pin dimensions 1.2 x 0.35 mm Reel diameter of tape-and-reel packaging 330 mm Tape width 24 mm 24.09.2019    Page 3/6 Data sheet  |  Item number: 2061-1603/998-404 www.wago.com/2061-1603/998-404 PCB contact PCB contact THR Solder pin arrangement over the entire terminal strip, in line Number of solder pins per potential 2 Material Data Color white Material group I Insulating material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Weight 1.63 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Country of origin CN GTIN 4055143274753 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL7459 CCA DEKRA Certification B.V. EN 60838 NTR NL7721 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71100855 KEMA/KEUR DEKRA Certification B.V. EN 60838 71106232 24.09.2019    Page 4/6 Data sheet  |  Item number: 2061-1603/998-404 www.wago.com/2061-1603/998-404 UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 Compatible products tools Item no.: 2061-189 Operating tool; made of insulating material; for 2061 Series www.wago.com/2061-189 Item no.: 206-861 Operating tool; for 2061 Series www.wago.com/206-861 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 ferrule 24.09.2019    Page 5/6 Data sheet  |  Item number: 2061-1603/998-404 www.wago.com/2061-1603/998-404 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 3D Download 2061-1603/998-404   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2019    Page 6/6
2061-1603/998-404 价格&库存
很抱歉,暂时无法提供与“2061-1603/998-404”相匹配的价格&库存,您可以联系我们找货
2061-1603/998-404
  • 1+47.670981+6.19579
  • 10+33.8607010+4.40087
  • 25+29.6943525+3.85937
  • 50+27.1114050+3.52367
  • 100+24.98767100+3.24765
库存:66
2061-1603/998-404
  • 320+22.30458320+2.89893
  • 640+21.13582640+2.74702
  • 960+20.57237960+2.67379
  • 1600+19.969821600+2.59548
  • 2240+19.630062240+2.55132
  • 3200+19.313003200+2.51011
库存:66
