216-203
216-203
    WAGO(万可电子)
216-203 数据手册
Printview: Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 - Item No.: 216-203 . Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 Item No.: 216-203 . Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 . Marking . Business data Supplier WAGO Item no. 216-203 GTIN / EAN 4017332277471 Content 1 Order amount 100 Customer item number . Notes Technical data Miscellaneous Color red Strip length 1 10 mm / 0.39 in Fire load [MJ] 0.001 [MJ] Weight [g] 0.107 [g] Diameter [mm] 3.6 [mm] Diameter 1 [mm] 3 [mm] Diameter 2 [mm] 1.5 [mm] Length [mm] 14 [mm] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 - Item No.: 216-203 Technical data Length 1 [mm] 8 [mm] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 - Item No.: 216-203 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 - Item No.: 216-203 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Ferrule; sleeve for 1 mm² / awg 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 - Item No.: 216-203 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
216-203 价格&库存
很抱歉,暂时无法提供与“216-203”相匹配的价格&库存,您可以联系我们找货
  • 1+1.143661+0.14803
  • 10+0.9428710+0.12204
  • 50+0.7769950+0.10057
  • 100+0.71588100+0.09266
  • 300+0.61985300+0.08023
  • 500+0.58493500+0.07571
库存:7102
216-203
  • 5+1.07417
  • 50+0.83052
  • 150+0.70870
  • 500+0.61733
  • 2500+0.54422
  • 5000+0.50760
      • 1+62.55592
      库存:6400
      216-203
      • 1+2.112191+0.27340
      • 10+1.7729610+0.22949
      • 25+1.6620225+0.21513
      • 50+1.5826550+0.20485
      • 100+1.50670100+0.19502
      • 300+1.39440300+0.18049
      • 500+1.34478500+0.17407
      • 1000+1.280551000+0.16575
      • 2500+1.200282500+0.15536
      库存:35966
