2202-2703
2202-2703
    WAGO(万可电子)
    WAGO - 2202-2703 - THROUGH/THROUGH TERMINAL BLOCK, L/N, GREY 51AH5124
2202-2703 数据手册
Data sheet  |  Item number: 2202-2703 Double-deck terminal block; with push-button; Through/through terminal block; L/N; without marker carrier; suitable for Ex e II applications; Blue conductor entry upper deck; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Pushin CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2202-2703 Color: Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 24 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology Push-in CAGE CLAMP® Number of connection points (connection type) 2 Actuation type Push-button Connectable conductor materials Copper Nominal cross section 2.5 mm² Solid conductor Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 0.25 … 4 mm² / 22 … 12 AWG Do you have any questions about our products? We are always happy to take your call at {0}. 27.01.2020    Page 1/2 Data sheet  |  Item number: 2202-2703 www.wago.com/2202-2703 Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor, push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 1 … 2.5 mm² / 18 … 12 AWG Fine-stranded conductor with ferrule, push-in termination, from 1 … 2.5 mm² / 18 … 12 AWG Strip length 10 … 12 mm / 0.39 … 0.47 inch Number of connection points 2 Total number of connection points 4 Total number of potentials 2 Number of levels 2 Type of wiring Front-entry wiring Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Geometrical Data Width 5.2 mm / 0.205 inch Height from upper-edge of DIN-35 rail 71.7 mm / 2.035 inch Depth 92.5 mm / 3.642 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Potential marking L/N Marking level Center/side marking Material Data Color gray Insulating material Polyamide 66 (PA 66) Weight 12.6 g Commercial data Packaging type BOX Country of origin DE GTIN 4055143844475 Customs Tariff No. 85369010000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at {0}. 27.01.2020    Page 2/2
2202-2703 价格&库存
很抱歉,暂时无法提供与“2202-2703”相匹配的价格&库存,您可以联系我们找货
    • 1+2256.45980
    库存:250
    2202-2703
      • 1+554.60972
      库存:250
      2202-2703
      • 1+95.311551+12.39020
      • 10+67.6017210+8.78801
      • 25+59.7610125+7.76874
      • 50+55.0077150+7.15083
      • 100+51.15448100+6.64992
      • 250+47.22872250+6.13958
      • 500+44.97915500+5.84715
      • 1000+43.222941000+5.61885
      库存:20
