231-140/001-000
231-140/001-000
    WAGO(万可电子)
231-140/001-000 数据手册
Data sheet from 06.02.2007 Item no.: 231-140/001-000 Product description: HEADER; STRAIGHT SOLDER PIN, 1X1 MM / 0.039X 0.039 IN; 10 POLE; PIN SPACING 5 MM / 0.197 IN; MATING DIRECTION PERPENDICULAR TO PCB; WITH CLOSED END Packing unit 100 4*25 pieces Pin spacing from 5 mm Pin spacing from 0.197 in pole count 10 Voltage CSA 300 V Voltage UL 300 V Current rating UL 10 A Current rating CSA 10 A Measured voltage EN 250 V Measured shock voltage 4 kV Pollution degree 3 Current intensity EN 12 A Weight 3.34 g Color gray Height 12 mm Height 0.472 in Width 53.2 mm Width 2.094 in Depth 8.4 mm Depth 0.331 in 1 von 2 Data sheet from 06.02.2007 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 231-140/001-000 ABS 04-HG469925-PDA 400 12 5,0 231-140/001-000 BBJ B/12/699/03 250 12 5,0 231-140/001-000 BV 11915/A0 400 16 2,5 231-140/001-000 CCA DK2127 400 12 5,0 231-140/001-000 CSA 154112-1466354 300 10 1x1 231-140/001-000 CSM 017956 500/250 12 5,0 231-140/001-000 DEMKO 88126 250 16 2,5 231-140/001-000 GL 17296-00HH 400 12 5,0 231-140/001-000 KEMA 98.2486.01 250 12 231-140/001-000 KR HMB05880-EL003 250/400 12/16 2,5 231-140/001-000 LR 96/20035 400 12 5,0 231-140/001-000 RMR 11130002 400 12 5,0 231-140/001-000 RosTesT B09523 400 12 5,0 231-140/001-000 UL E45171 600 10 1x1 231-140/001-000 UL E45172 300 10 1x1 231-140/001-000 VDE 5675ÜGBl.2 250 12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 2 von 2
231-140/001-000 价格&库存
很抱歉,暂时无法提供与“231-140/001-000”相匹配的价格&库存,您可以联系我们找货
  • 15+54.1236015+7.00956
  • 50+32.5125950+4.21071
  • 100+31.43267100+4.07085
  • 250+29.09124250+3.76761
库存:485
231-140/001-000
  • 4+29.274614+3.79136
  • 10+27.9377810+3.61823
  • 25+26.8472425+3.47699
  • 100+19.53658100+2.53019
  • 500+19.06472500+2.46908
  • 1000+18.538551000+2.40093
库存:112
231-140/001-000
  • 1+28.755841+3.72418
  • 10+27.4440510+3.55429
  • 25+26.3722125+3.41547
  • 100+19.19051100+2.48537
  • 500+18.72754500+2.42541
  • 1000+18.210391000+2.35843
库存:113
