Printview: 1-conductor PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with
push-button; modular - Item No.: 235-401/331-000
spacing 5/5.08 mm / 0.2 in; with push-button; modular
1-conductor PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button; modular
Marking
Business data
Supplier
WAGO
Item no.
235-401/331-000
GTIN / EAN
4044918830003
Content
1
Order amount
100
Customer item number
Notes
Modular terminal blocks with push-buttons for custom terminal strip assembliesSimple, push-in terminations of solid
and ferruled conductorsConvenient termination/removal of fine-stranded conductors via push-buttonsSet to metric or
inch pin spacing by compressing terminal strips together or pulling them apart
Technical data
Miscellaneous
No. of poles
1
Pin Spacing
5/5.08 mm / 0.2 in
Total number of connection points
1
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Pollution degree (1)
2
Rated voltage EN (1) [V]
320 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
17.5 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
17.5 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
250 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
17.5 [A]
Number of individual connection objects at the product
1
Connection technology (1)
Push-in CAGE CLAMP®
Solid sizes 1
0.2 … 1.5 mm² / 20 … 14 AWG
Fine-stranded wires with insulated ferrule 1
0.25 … 0.75 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 0.75 mm² / …
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Side-entry wiring
Solder pin arrangement
in-line solder pin
Solder pin length [mm]
3.6 [mm]
Solder pin width A [mm]
0.4 [mm]
Solder pin width B [mm]
0.8 [mm]
Tolerance of drilled hole [mm]
1(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.013 [MJ]
2
Technical data
Weight [g]
0.758 [g]
Width
5 mm / 0.197 in
Height
19.1 mm / 0.752 in
Height from the surface
15.5 mm / 0.61 in
Length
12.5 mm / 0.492 in
3
Images & drawings
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“235-401/331-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.477571+1.10024
- 10+6.2514110+0.81132
- 25+5.4423025+0.70632
- 50+4.9056850+0.63667
- 100+4.44208100+0.57650
- 300+3.85463300+0.50026
- 500+3.63788500+0.47213
- 1000+3.394201000+0.44051
- 5000+3.005625000+0.39008
