236-408
236-408
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 脚间距:5.08mm 每排Pin数:8 排数:1
236-408 数据手册
Data sheet Item no.: Product description: 261-306 2-CONDUCTOR TERMINAL BLOCK FOR SCREW OR SIMILAR MOUNTING TYPES 3.2 MM Ø MOUNTING ADAPTER AVAILABLE FOR TS 35 (209-123) Packing unit 200 4*50 pieces Product group Cross section [mm²] Cross section [AWG] Connection method Measured voltage EN Measured shock voltage Pollution degree Current intensity EN Weight Color Wiring type No. of connection Points No. of potentials Height Height Width Width Depth Depth Strip length from Strip length to Strip length © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 9 (Std Chassis Mt Blocks) 0.08 - 2.5 mm² 28 - 14 AWG CAGE CLAMP® CONNECTION 500 V 6 kV 3 24 A 2.26 g orange Side-entry 2 1 18 mm 0.709 in 6 mm 0.236 in 28 mm 1.103 in 8 mm 9 mm 0.33 in
236-408 价格&库存
很抱歉,暂时无法提供与“236-408”相匹配的价格&库存,您可以联系我们找货
  • 1+2939.48255
库存:302
236-408
  • 5+57.11782
库存:15
