249-126
249-126
    WAGO(万可电子)
249-126 数据手册
Printview: Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 0.75 mm² Item No.: 249-126 . Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 0.75 mm² Item No.: 249-126 . Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 0.75 mm² . Marking . Business data Supplier WAGO Item no. 249-126 GTIN / EAN 4044918786416 Content 1 Order amount 10 Customer item number . Notes Technical data Miscellaneous Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 9 [A] Fire load [MJ] 0.023 [MJ] Weight [g] 2.5 [g] Wire length of wire jumpers [mm] L = 110 [mm] Safety information 1 Note: Push down the wire jumper until fully inserted! WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 0.75 mm² Item No.: 249-126 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Push-in type wire jumper; insulated; wire length 110 mm; conductor cross section 0.75 mm² Item No.: 249-126 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
249-126 价格&库存
很抱歉,暂时无法提供与“249-126”相匹配的价格&库存,您可以联系我们找货
