256-747
256-747
    WAGO(万可电子)
    插件
    接线端子 每排针脚数:1 排数:单排
256-747 数据手册
Printview: Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button - Item No.: 256-747 . Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button Item No.: 256-747 . Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button . Marking . Business data Supplier WAGO Item no. 256-747 GTIN / EAN 4044918758932 Content 1 Order amount 100 Customer item number . Notes Modular terminal blocks with push-button actuated CAGE CLAMP®Also available with Ex e approvalSet to metric or inch pin spacing by compressing terminal strips together or pulling them apartIdeal for in-the-field wiring thanks to simplified push-button actuationConvenient, tool-free operation Technical data Miscellaneous No. of poles 1 Pin Spacing 5/5.08 mm / 0.2 in Total number of connection points 1 Total number of potentials 1 Color light green Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button - Item No.: 256-747 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 24 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 24 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 250 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 24 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 1.5 mm² / … Strip length 1 5 … 6 mm / 0.2 … 0.24 in Conductor entry angle to the PCB 1 [°] 45 [°] Solder pin arrangement in-line solder pin Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.7 [mm] Solder pin width B [mm] 0.7 [mm] Tolerance of drilled hole [mm] 1.1(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button - Item No.: 256-747 Technical data Fire load [MJ] 0.013 [MJ] Weight [g] 0.967 [g] Width 5 mm / 0.197 in Height 22.2 mm / 0.874 in Height from the surface 18.2 mm / 0.717 in Length 17.6 mm / 0.693 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button - Item No.: 256-747 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Modular PCB terminal block; 2 solder pins/pole; 1-pole; pin spacing 5/5.08 mm / 0.2 in; with push-button - Item No.: 256-747 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
256-747 价格&库存
很抱歉,暂时无法提供与“256-747”相匹配的价格&库存,您可以联系我们找货
    • 1+366.04638
    库存:300
    256-747
    • 1+3.73680
    • 10+2.94840
    • 30+2.55960
    • 100+2.17080
    库存:203
