2626-1105/020-004
2626-1105/020-004
    WAGO(万可电子)
2626-1105/020-004 数据手册
Data sheet | Item number: 2626-1105/020-004 PCB terminal block; 6 mm²; Pin spacing 7.5 mm; 5-pole; Push-in CAGE CLAMP®; 6,00 mm²; black https://www.wago.com/2626-1105/020-004 Color: • • • • Dimensions in mm L = (pole no. – 1) x pin spacing + 9.3 mm black PCB terminal strips with Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Ideal for panel feedthrough applications via operation parallel to conductor entry Testing can be performed both parallel and perpendicular to conductor entry Notes Variants: Other pole numbers Direct marking Other colors Other versions (or variants) can be requested from WAGO Sales or configured at https:// configurator.wago.com/. . Electrical data Ratings per IEC/EN Ratings per IEC/EN Ratings per IEC/EN 60664-1 Rated current 48 A Nominal voltage (III/3) 1000 V Legend (ratings) Rated impulse voltage (III/3) 8 kV (III / 2) ≙ Overvoltage category III / Polluti­ on degree 2 Rated voltage (III/2) 1000 V Rated impulse voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Page 1/5 . Version 01.04.2022 Continued on next page Data sheet | Item number: 2626-1105/020-004 https://www.wago.com/2626-1105/020-004 Ratings per UL Ratings per CSA Approvals per UL 1059 Approvals per CSA Rated voltage UL (Use Group B) 600 V Rated voltage CSA (Use Group B) 600 V Rated current UL (Use Group B) 38 A Rated current CSA (Use Group B) 31 A Rated voltage UL (Use Group C) 600 V Rated voltage CSA (Use Group C) 600 V Rated current UL (Use Group C) 38 A Rated current CSA (Use Group C) 31 A . . Connection data Total number of connection points 5 Connection 1 Total number of potentials 5 Connection technology Push-in CAGE CLAMP® Number of connection types 1 Actuation type Operating tool Number of levels 1 Solid conductor 0.2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor 0.2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 6 mm² Fine-stranded conductor; with uninsula­ ted ferrule 0.25 … 6 mm² Fine-stranded conductor; with twin ferru­ le 0.25 … 2.5 mm² Strip length 13 … 15 mm / 0.51 … 0.59 inch Conductor connection direction to PCB 0° Pole number 5 . . Physical data Pin spacing 7.5 mm / 0.295 inch Width 39.3 mm / 1.547 inch Height 23.6 mm / 0.929 inch Height from the surface 19.6 mm / 0.772 inch Depth 24.2 mm / 0.953 inch Solder pin length 4 mm Solder pin dimensions 1.5 x 1 mm Drilled hole diameter with tolerance 2 (+0.1) mm . Mechanical data Mounting type Feed-through mounting . PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (staggered) Number of solder pins per potential 1 . Page 2/5 Version 01.04.2022 Continued on next page Data sheet | Item number: 2626-1105/020-004 https://www.wago.com/2626-1105/020-004 Material data Note (material data) Information on material data can be found here Color black Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating Tin Fire load 0 MJ Weight 19.8 g . Environmental requirements Limit temperature range -60 … +105 °C . Commercial data eCl@ss 10.0 27-44-04-01 eCl@ss 9.0 27-44-04-01 ETIM 7.0 EC002643 ETIM 6.0 EC002643 PU (SPU) 60 Stück Packaging type Box Country of origin VKOrg Germany PL GTIN 4055143766012 Customs tariff number VKOrg Germany 85369010000 . Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 2626-1105/020-004 . Documentation Additional Information Technical Section 03.04.2019 pdf 1949.09 KB . Page 3/5 Version 01.04.2022 Continued on next page Data sheet | Item number: 2626-1105/020-004 https://www.wago.com/2626-1105/020-004 CAD/CAE-Data CAD data CAE data 2D/3D Models 2626-1105/020-004 ZUKEN Portal 2626-1105/020-004 . . 1 Compatible products 1.1 Optional accessories 1.1.1 Ferrule 1.1.1.1 Ferrule Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; in­ sulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black Item no.: 216-208 Ferrule; Sleeve for 6 mm² / AWG 10; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-108 Ferrule; Sleeve for 6 mm² / AWG 10; unin­ sulated; electro-tin plated; silver-colored Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; in­ sulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray . 1.1.2 Tool 1.1.2.1 Operating tool Item no.: 210-721 Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured . Installation notes Conductor termination Insert fine-stranded conductors and re­ move all conductor types via operating tool. . Page 4/5 Version 01.04.2022 Continued on next page Data sheet | Item number: 2626-1105/020-004 https://www.wago.com/2626-1105/020-004 Conductor termination Insert solid conductors via push-in termi­ nation. . Subject to changes. Please also observe the further product documentation! Current addresses can be found at: w w w.wago.com Page 5/5 Version 01.04.2022
2626-1105/020-004 价格&库存
很抱歉,暂时无法提供与“2626-1105/020-004”相匹配的价格&库存,您可以联系我们找货
2626-1105/020-004
  • 11+43.67270
库存:39
