2626-1359
2626-1359
    WAGO(万可电子)
    插件,P=12.5mm
    接线端子 间距:12.50mm 每排针脚数:9 排数:单排
2626-1359 数据手册
Data sheet  |  Item number: 2626-1359 PCB terminal block; 6 mm²; Pin spacing 12.5 mm; 9-pole; Push-in CAGE CLAMP®; 6,00 mm²; gray www.wago.com/2626-1359 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 1/6 Data sheet  |  Item number: 2626-1359 www.wago.com/2626-1359 L = (pole no. - 1) x pin spacing + 9.3 mm Item description PCB terminal strips with Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Ideal for panel feedthrough applications via operation parallel to conductor entry Testing can be performed both parallel and perpendicular to conductor entry Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 1000 V Rated surge voltage (III/3) 8 kV Rated voltage (III/2) 1000 V Rated surge voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Rated current 48 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 2/6 Data sheet  |  Item number: 2626-1359 www.wago.com/2626-1359 Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 38 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 38 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Solid conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor; with insulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with uninsulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with twin ferrule 0,25 … 2,5 mm² Strip length 13 … 15 mm / 0.51 … 0.59 inch Conductor connection direction to PCB 0  ° Pole No. 9 Total number of connection points 9 Total number of potentials 9 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 12,5 mm / 0.492 inch Width 109,3 mm / 4.303 inch Height 23,6 mm / 0.929 inch Height from the surface 19,6 mm / 0.772 inch Depth 24,2 mm / 0.953 inch Solder pin length 4 mm Solder pin dimensions 1,5 x 1 mm Drilled hole diameter with tolerance 2 (+0,1) mm Mechanical data Mounting type Feed-through mounting PCB contact Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 3/6 Data sheet  |  Item number: 2626-1359 www.wago.com/2626-1359 PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material Data Color gray Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 48.7 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Packaging type BOX Country of origin DE GTIN 4055143861700 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 70146882 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71107864 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 4/6 Data sheet  |  Item number: 2626-1359 www.wago.com/2626-1359 Counterpart Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data PCB Design Symbol and Footprint 2626-1359 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 5/6 Data sheet  |  Item number: 2626-1359 www.wago.com/2626-1359 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Handling Instructions Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 6/6
2626-1359 价格&库存
很抱歉,暂时无法提供与“2626-1359”相匹配的价格&库存,您可以联系我们找货
    • 9+106.76355
    • 27+101.73370
    • 107+97.07866
    • 268+92.87099
    库存:721
    2626-1359
      • 11+74.1145411+9.61630
      • 55+66.7118055+8.65580
      库存:721
