2706-102
2706-102
    WAGO(万可电子)
    插件,P=7.5mm
    接线端子 间距:7.50mm 每排针脚数:2 排数:单排
2706-102 数据手册
Wago #2706-102 Description Terminal strips with operating levers; 2 solder pins/pole; 7-pole; pin spacing 12.5 mm / 0.492 in; without jumper slot Features      High-current terminal strips with lever-actuated CAGE CLAMP® Tool-free opening and closing – fingers open/close levers Several clamping units can be held open simultaneously – convenient for terminating multi-core cables Two solder pins per contact point for high mechanical stability 600V UL for 12.5mm pin spacing Item properties Name Value Unit No. of Poles 7 Total number of connection points 7 Total number of potentials 7 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 1000 V Rated surge voltage (1) [kV] 8 kV Nominal current [A] 41 A Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 1000 V Rated surge voltage (2) [kV] 8 kV Nominal current (2) [A] 41 A Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 1000 V Rated surge voltage (3) [kV] 8 kV Nominal current (3) [A] 41 A Connection technology (1) CAGE CLAMP® Conductor type (1) solid Cross section from (1) [mm²] 0.5 mm² Cross section up to (1) [mm²] 6 mm² Cross section from (1) [AWG] 20 AWG Cross section up to (1) [AWG] 10 AWG Conductor type (2) stranded Cross section from (2) [mm²] 0.5 mm² Cross section up to (2) [mm²] 6 mm² Conductor type (3) fine-stranded (with insulated ferrule) Cross section from (3) [mm²] 0.5 mm² Cross section up to (3) [mm²] 6 mm² Conductor type (4) fine-stranded (with uninsulated ferrule) Cross section from (4) [mm²] 0.5 mm² Cross section up to (4) [mm²] 6 mm² Strip length from 1 [mm] 11 mm Strip length up to (1) [mm] 12 mm Strip length from [inch] [in] 0.43 in Strip length up to [inch] [in] 0.47 in Strip length (1) [in] 0.45 in Conductor entry angle to the PCB (degrees) [°] 30 ° Solder pin length [mm] 4.5 mm Solder pin width A [mm] 1 mm Solder pin width B [mm] 1.4 mm Drilled hole diameter [mm] [mm] 1.8 mm Tolerance of drilled hole diameter [mm] [mm] +0.1 mm Material group I Insulating material Polyamide 6.6 (PA 6.6) Flammability rating per UL 94 V0 Lower limit temperature [C] -60 C Upper temperature limit [C] 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 1.001 MJ Weight [g] 47.379 g Width [mm] 82.5 mm Width [in] 3.248 in Height [mm] 25.5 mm Altitude [in] 1.004 in Length [mm] 26 mm Length [in] 1.024 in Pin spacing from [mm] 12.5 mm Pin spacing from [in %] 0.492 in %
2706-102 价格&库存
很抱歉,暂时无法提供与“2706-102”相匹配的价格&库存,您可以联系我们找货
  • 1+27.11880
  • 10+22.83120
  • 30+20.28240
库存:72
2706-102
    • 85+13.44700
    库存:200
    2706-102
      • 1+2537.74795
      库存:170
