2773-402
2773-402
    WAGO(万可电子)
    WAGO - 2773-402 - Standard Terminal Block, 2773 Series, 2 Contacts, Push In, Cable Mount, 12 AWG
2773-402 数据手册
Data sheet | Item number: 2773-402 COMPACT splicing connector; for solid and stranded conductors; max. 4 mm²; 2-conductor; transparent housing; white cover; Surrounding air temperature: max 85°C (T85); 4,00 mm²; transparent www.wago.com/2773-402 Item description Advantages: Convenient wiring via extremely compact design Push-in termination of up to eight solid and stranded conductors Conductor range: 0.75 … 4 mm² “s” and 1.5 … 4 mm² “st” Any combination of conductor sizes is possible PUSH WIRE® connection terminates solid (“s”) copper conductors Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.05.2021    Page 1/5 Data sheet | Item number: 2773-402 www.wago.com/2773-402 Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60998 Nominal voltage (II/2) 450 V Rated surge voltage (II/2) 4 kV Rated current 32 A Legend (ratings) (II / 2) ≙ Overvoltage category II / Pollution degree 2 Ratings per UL Approvals per UL 486C Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 20 A Connection data Connection technology PUSH WIRE® Actuation type Push-in Connectable conductor materials Copper Solid conductor 0.75 … 4 mm² / 20 … 12 AWG Stranded conductor 1.5 … 4 mm² / 18 … 12 AWG Conductor diameter 1.6  …  2 mm Strip length 13 mm / 0.51 inch Total number of connection points 2 Total number of potentials 1 Wiring type Side-entry wiring Physical data Width 11.6 mm / 0.457 inch Height 6.3 mm / 0.248 inch Depth 18.6 mm / 0.732 inch Material data Color transparent Cover color white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.05.2021    Page 2/5 Data sheet | Item number: 2773-402 www.wago.com/2773-402 Cover color white Flammability class per UL94 V2 Fire load 0.006 MJ Weight 1.1 g Environmental requirements Surrounding air temperature (operation) 85 °C Continuous operating temperature -40 … +105 °C Temperature marking per EN 60998 T85 Commercial data Packaging type BOX Country of origin DE GTIN 4055143895408 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 60998 NL-49187 KEMA/KEUR DEKRA Certification B.V. EN 60669 71101844 Approval Additional Approval Text UL Underwriters Laboratories Inc. UL 467 UL-Approvals Logo Certificate name 20180215E201573 Optional accessories Mounting adapter Item no.: 2773-500 Mounting carrier; for single- and double-row con.; 2773 Series; for DIN-35 rail mounting/screw www.wago.com/2773-500 mounting; orange Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.05.2021    Page 3/5 Data sheet | Item number: 2773-402 www.wago.com/2773-402 Mounting carrier; for single- and double-row con.; 2773 Series; for DIN-35 rail mounting/screw www.wago.com/2773-500 mounting; orange Downloads Documentation Additional Information Technical explanations 2019 Apr 3 pdf 2.2 MB Download Installation Notes Conductor termination Strip solid or stranded conductor to 13 mm (0.51 inch). The transparent housing shows if conductors are fully inserted; within the colored base, a clear port shows if the conductor's strip length is correct. Conductors are correctly stripped if the clear port shows no bare conductor on the unprinted connector side. Picture shows center conductor with exceeded strip length. Termination: Insert the stripped conductor until it hits the backstop. Removal: Hold solid conductor to be removed and twist alternately left and right while pulling the connector. Solid conductors are inserted into the connector by simply pushing them in. Stranded conductors are inserted into the connector by simply pushing them in. Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.05.2021    Page 4/5 Data sheet | Item number: 2773-402 www.wago.com/2773-402 Testing Testing via test port opposite to conductor entry. Application Thanks to their flat and compact design, these connectors are ideal for wiring in flushmount switch boxes. With six variants, always have the right connector. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.05.2021    Page 5/5
2773-402 价格&库存
很抱歉,暂时无法提供与“2773-402”相匹配的价格&库存,您可以联系我们找货
    • 500+1.10740
    库存:1000
