Data sheet | Item number: 2787-2347 NEW
Power supply; Pro 2; 3-phase; 24 VDC output voltage; 20 A output current;
TopBoost + PowerBoost; communication capability
www.wago.com/2787-2347
Item description
Features:
Power supply with TopBoost, PowerBoost and configurable overload behavior
Configurable digital signal input and output, optical status indication, function keys
Communication interface for configuration and monitoring
Optional connection to IO-Link or Modbus RTU
Suitable for both parallel and series operation
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at 01788 568 008.
23.03.2021 Page 1/10
Natural convection cooling when horizontally mounted
Pluggable connection technology
Electrically isolated output voltage (SELV/PELV) per EN 61010/UL 61010
Marker slot for WAGO Marker Cards (WMB) and WAGO Marking Strips
Data
Technical data
Input
Phases
2
3
Nominal input voltage Ui nom
(2 / 3) x AC 400 … 500 V
Input voltage range
(2 / 3) x AC 340 … 550 V; DC 480 … 780 V
Input voltage derating
See instruction leaflet
Nominal mains frequency range
47 … 63 Hz; 0 Hz
Input current Ii
≤ 3 x 0.8 A (400 VAC; 20 ADC)
Inrush current
≤ 15 A (after 1 ms)
Power factor correction (PFC)
Active
Mains failure hold-up time
≥ 20 ms (3 x 400 VAC)
Output
Nominal output voltage Uo nom
DC 24 V (SELV)
Output voltage range
DC 24 … 28 V (adjustable)
Default setting
DC 24 V
Nominal output current Io nom
20 A (24 VDC)
Nominal output power
480 W
Control deviation
≤ 1 %
Residual ripple
≤ 70 mV (Peak-to-peak)
Current limitation
1.1 x Io nom (typ.)
Overload behavior
TopBoost/PowerBoost/Time-limited constant current mode (other
overload behaviors can be set)
PowerBoost
DC 30 A (5 s)
TopBoost
up to 600 %
Hansastr. 27
32423 Minden
23.03.2021 Page 2/10
Signaling and communication
Signaling
Optical status indication (DC OK; load; warning and error states)
Digital signal input and output (DI/DO)
Communication
Communication interface, can be used with WAGO USB
Communication Cable (750-923) or IO-Link Communication Module
(2789-9080) or Modbus RTU Communication Module (2789-9015)
Efficiency/power losses
Power loss Pl
≤ 3.6 W (Standby); ≤ 4.4 W (No load); ≤ 21 W (400 VAC; Nominal load)
Efficiency (typ.)
95.9 % (400 VAC; 20 A; 25 °C)
Circuit protection
Internal fuse
3 x T 2.5 A / 500 VAC
Required backup fusing
An external DC fuse is required for the DC input voltage.
Recommended backup fusing
3 x 16 A (for USA/Canada: 3 x 15 A)
Safety and protection
Isolation voltage (pri.-sec., AC)
3,510 V
Isolation voltage (pri.-GND, AC)
2,200 V
Isolation voltage (Sec.-GND)
DC 0.5 kV
Isolation voltage (Sec.-Signal)
DC 0.5 kV
Protection class
I
Protection type
IP20 (per EN 60529)
Resistance to reverse feed
≤ DC 35 V
Overvoltage category
III (≤ 2000 m a. s.l.); II (> 2000 m a. s.l.)
Pollution degree
2
Transient suppression (primary)
Yes
Overvoltage protection; secondary
Internal protective circuit
≤ 35 VDC (in the event of a fault)
Short-circuit-protected
Yes
Open-circuit-proof
Yes
Parallel operation
Yes
Series operation
Yes
MTBF
> 800,000 h (per IEC 61709)
Hansastr. 27
32423 Minden
23.03.2021 Page 3/10
Connection data
Connection type (1)
Input/signaling
Connection technology
CAGE CLAMP®
WAGO Connector
WAGO 721 Series
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm² / 20 … 14 AWG
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Connection type 2
Output
Connection technology 2
Push-in CAGE CLAMP®
WAGO Connector 2
WAGO 831 Series
Solid conductor 2
0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor 2
Fine-stranded conductor; with insulated ferrule 2
0.5 … 6 mm² /
Fine-stranded conductor; with uninsulated ferrule 2
0.5 … 6 mm² /
Strip length 2
13 … 15 mm / 0.51 … 0.59 inch
Physical data
Width
70 mm / 2.756 inch
Height
130 mm / 5.118 inch
Depth from upper edge of DIN-rail
130 mm / 5.118 inch
Note (dimensions)
Height without connector
Height with connector: 169 mm
Mechanical data
Mounting type
DIN-35 rail
Material data
Weight
1400 g
Environmental requirements
Surrounding air temperature (operation)
-25 … 70 °C (Device starts at −40 °C (type-tested))
Surrounding air temperature (storage)
-40 … 85 °C
Relative humidity
5 … 96 % (no condensation permissible)
Hansastr. 27
32423 Minden
23.03.2021 Page 4/10
Relative humidity
Derating
Pollution degree
2
Climatic category
3K3 (per EN 60721)
Operating altitude (max.)
5000 m
Standards and specifications
Conformity marking
CE
Standards/Specifications
EN 61010-1; EN 61010-2-201; EN 61204-3; UL 61010-1; UL 610102-201
Commercial data
Packaging type
BOX
Country of origin
CN
GTIN
4055143907163
Customs tariff number
85044082900
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate
name
UL
Underwriters Laboratories Inc. (HAZARDOUS
LOCATIONS)
UL 121201
E198726
Approval
Certificate
name
UL
UL 61010-2-201
E255817
UL-Approvals
Logo
Compatible products
Marking accessories
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
Item no.: 2009-115
Hansastr. 27
32423 Minden
www.wago.com/2009-110
www.wago.com/2009-115
23.03.2021 Page 5/10
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
General accessories
Item no.: 2789-9015
Communication module; Modbus RTU; RJ45; communication capability
www.wago.com/2789-9015
Item no.: 2789-9080
Communication module; IO-Link; communication capability
www.wago.com/2789-9080
Item no.: 750-923
Configuration cable; USB connector; Length: 2.5 m; black
www.wago.com/750-923
Item no.: 750-923/000-001
Configuration cable; USB connector; Length: 5 m
/000-001
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
ferrule
Item no.: 216-203
Hansastr. 27
32423 Minden
www.wago.com/216-203
23.03.2021 Page 6/10
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-207
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; gray
www.wago.com/216-207
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
Hansastr. 27
32423 Minden
23.03.2021 Page 7/10
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-721
tools
Downloads
Documentation
Bid Text
2787-2347_EUSA
4 Jul 2019
xml
8.1 kB
Download
4 Jul 2019
docx
23.6 kB
Download
X81 - Datei
2787-2347_EUSA
docx - Datei
Hansastr. 27
32423 Minden
23.03.2021 Page 8/10
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
pdf
265.8 kB
Download
1.0.5.03
14 Sep 2020
exe
29.8 MB
Download
exe
113.7 MB
Download
URL
Download
EPLAN Data Portal 2787-2347
URL
Download
ZUKEN Portal 2787-2347
URL
Download
URL
Download
Engineering-Software
Software for Interface-Products
WAGO Interface Configuration Software G2 SMALL
The full setup only includes the WAGO Interface Configuration Software G2.
WAGO Interface Configuration Software G2 FULL
1.0.5.03
The full setup, in addition to the WAGO Interface Configuration Software G2, includes 14 Sep 2020
the installation for the Microsoft .NET Framework.
CAD/CAE-Data
CAD data
2D/3D Models 2787-2347
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2787-2347
Power supply; Pro 2; 3-phase; 24 VDC output voltage; 20 A output current; TopBoost
Installation Notes
Hansastr. 27
32423 Minden
23.03.2021 Page 9/10
Product family
Pro 2
Show all products from the family
Hansastr. 27
32423 Minden
23.03.2021 Page 10/10
很抱歉,暂时无法提供与“2787-2347”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5072.267701+657.03607
- 10+4458.1075610+577.48085
