Data sheet from 22.08.2012
Item no.:
280-834
Product description:
4-conductor through terminal block SUITABLE FOR EX I
APPLICATIONS
Produkt kann von Bild abweichen / product may differ
Packing unit 100 pieces
RoHS compliant
Product group
1 (Rail Mounted Terminal Blocks)
Cross section [mm²]
0.08 - 2.5 mm²
Cross section [AWG]
28 - 12 AWG
Connection method
CAGE CLAMP® CONNECTION
Measured voltage EN
800 V
Measured shock voltage
8 kV
Pollution degree
3
Current intensity EN
20 A
Weight
9.016 g
Color
blue
Wiring type
Front-entry
No. of connection Points
4
No. of potentials
1
Height
28 mm
Height
1.1 in
Width
5 mm
Width
0.197 in
Depth
75 mm
Depth
1 von 3
2.95 in
Strip length from
8 mm
Strip length to
9 mm
Strip length
0.33 in
Mounting
TS 35
2 von 3
Item no.
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
280-834
ABS
05-HG476175/3-PDA
800
280-834
BV
07436/C0
800
280-834
CCA
NL5855
800
24
2,5
280-834
CSA
154112-1536071
600
15
28-12
280-834
DNV
E-10423
800
280-834
GL
17295-00HH
800
24
2,5
280-834
KEMA
2082859.07
800
24
2,5
280-834
LR
91/20112(E6)
800
280-834
PRS
TE/1718/880590/08
800
24
2,5
280-834
RMR
11130002
800
280-834
UR
E45172
600
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
很抱歉,暂时无法提供与“280-834”相匹配的价格&库存,您可以联系我们找货
