280-904
280-904
    WAGO(万可电子)
280-904 数据手册
Printview: 2-conductor through terminal block; suitable for Ex i applications - Item No.: 280-904 . 2-conductor through terminal block; suitable for Ex i applications Item No.: 280-904 . 2-conductor through terminal block; suitable for Ex i applications . Marking . Business data Supplier WAGO Item no. 280-904 GTIN / EAN 4044918391870 Content 1 Order amount 100 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color blue Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 24 [A] Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor through terminal block; suitable for Ex i applications - Item No.: 280-904 Technical data Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Strip length 1 8 … 9 mm / 0.31 … 0.35 in Note (conductor cross-section) 12 AWG: THHN, THWN Type of wiring Front-entry wiring Design horizontal Marking level Center marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.106 [MJ] Weight [g] 5.676 [g] Width 5 mm / 0.197 in Height from upper-edge of DIN-rail [mm] 28 [mm] Height from upper-edge of DIN-rail 28 mm / 1.102 in Length 53 mm / 2.087 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor through terminal block; suitable for Ex i applications - Item No.: 280-904 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor through terminal block; suitable for Ex i applications - Item No.: 280-904 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
280-904 价格&库存
很抱歉,暂时无法提供与“280-904”相匹配的价格&库存,您可以联系我们找货
    • 5+9.65666
    库存:10
