2857-569
2857-569
    WAGO(万可电子)
    WAGO - 2857-569 - Signal Converter, Current, Voltage, Current, Voltage, Digital, Relay, 24 VDC
2857-569 数据手册
Data sheet | Item number: 2857-569 Single-Phase Power Signal Conditioner; Current and voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC www.wago.com/2857-569 Item description Short description: This 1-phase power measurement module monitors and reports signal states with up to two switching thresholds. The sensor and status information that is collected is also converted to a standard analog signal. Current, voltage, effective power, apparent power or reactive power can be selected as the measured variable. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 1/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 be selected as the measured variable. Additionally, both frequency and phase angle are displayed. Features: A relay with changeover contact reacts to configured measurement range limits (on/off switching delay and threshold value switch function can be configured with up to two threshold values). Adjustable software filter Simulation of input/output response via WAGO Interface Configuration Display Analog unipolar/bipolar signals (current/voltage) at output Additional digital signal output for configured measurement range limits The digital output can be configured as a frequency generator or pulse output (S0 interface). Notice: The device is supplied with 24 VDC, which can be commoned using lateral push-in type jumper bars: (6.1) US+ (BR) and (6.2) GND 2 (BR). With this variant, it is necessary to ensure that the max. permissible total current of 6 A is not exceeded. Note: This product is supplied with 24 VDC, which can be commoned using lateral push-in type jumper bars: (6.1) US+ (BR) and (6.2) GND 2 (BR). With this variant, it is necessary to ensure that the maximum permissible total current of 6 A is not exceeded. Additional setting options via WAGO Interface Configuration Software or WAGO Configuration Display Data Technical data Configuration Configuration options WAGO Interface Configuration Software WAGO Configuration Display Input Input signal type Voltage Current Input signal (voltage) AC/DC 500 V (IN 2.1; per EN 61010-1); AC/DC 300 V (IN 2.1; per UL 61010-1); AC/DC 250 V (IN 2.2) ; AC/DC 30 V (IN 2.3) Input signal (current) AC/DC 1 A (IN 3.1); AC/DC 5 A (IN 3.2) ; AC/DC 8 A (IN 3.3) Frequency range 15 … 400 Hz Input current (max.) 1.2 × IN (≤ 60 °C); 1 × IN (60 … 70 °C) Input voltage (max.) 1.2 × UN Response threshold (voltage) 500 mVAC / 600 mVDC (IN 2.1) 50 mVAC / 500 mVDC (IN 2.2) 20 mVAC / 100 mVDC (IN 2.3) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 2/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 20 mVAC / 100 mVDC (IN 2.3) Response threshold (current) 1.5 mA AC / 7.5 mA DC (IN 3.1) 3 mA AC / 10 mA DC (IN 3.2) 7.5 mA AC / 12 mA DC (IN 3.3) Resolution (voltage) 50 mV (IN 2.1) 30 mV (IN 2.2) 5 mV (IN 2.3) Resolution (current) 1 mA (for all measurement ranges) Output – analog Output signal type Current Voltage Output signal (voltage) ± 12 V (SELV) Output signal (current) ±24 mA (SELV) Load impedance (voltage output) ≥ 2 kΩ Load impedance (current output) ≤ 600 Ω Output – digital Switching voltage (DO) (max.) Supply voltage (applied): −0.3 V Continuous current (DO) (max.) 100 mA (no internal restriction) Number of switching thresholds (DO) 2 (max.) Configurable rise/fall delay time (DO) 0 … 60 s (via software) Configurable functions (DO) Disabled US/GND switching Threshold value switch Frequency generator Pulse output (S0 interface) Output – relay Number of changeover/switchover contacts 1 Switching voltage (max.) AC 250 V Limiting continuous current (relay; module assembly) 6 A (≤ 60 °C); 3 A (60 … 70 °C) Dielectric strength, open contact (AC, 1 min) 1 kVrms Number of switching thresholds (relay) 1 or 2 (adjustable) Configurable rise/fall delay time (relay) 0 … 60 s (via software) Signal processing Measurement method True RMS measurement (TRMS) Measured variables (calculated) Active power Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 3/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Measured variables (calculated) Active power Apparent power Reactive power Mains frequency Phase angle Limit frequency 2 kHz Software filter (adjustable) Filter level: 1 … 30 Step response (max.) 350 ms (for default settings) Measurement error Transmission error (max.) ≤ 0.5 % for current and voltage (of the full scale value) Supply Power supply type 24 VDC Nominal supply voltage US DC 24 V (SELV) Supply voltage range ±30 % Power consumption at nominal supply voltage ≤ 70 mA (+ IDO) Safety and protection Measurement category per EN/UL 61010-2-030 CAT III (input) Overvoltage category III Note on insulation parameters The digital output (DO) is at the potential of the supply The service interface is at the potential of the analog output Protection type IP20 Test voltage Test voltage (input IN 2.1/relay output; per EN 61010-1) 5.4 kVAC ; 50 Hz; 5 s 3.6 kVAC; 50 Hz; 1 min Test voltage (input IN 2.1/relay output; per UL 61010-1) 3.51 kVAC; 60 Hz; 1 min Test voltage (input/supply, analog output/relay output) 3.51 kVAC; 50 … 60 Hz; 1 min Test voltage (supply/analog output) 3.6 kVAC; 50 … 60 Hz; 1 min Insulation parameters per EN/UL 61010-1 Line-to-neutral conductor voltage (AC) max. 300 V Overvoltage category III Pollution degree 2 Insulation type (input/supply, analog output/relay output) Basic insulation; Electrical isolation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 4/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Insulation parameters per EN 61010-1 Line-to-neutral conductor voltage (AC) max. 600 V Overvoltage category III Pollution degree 2 Insulation type (input IN 2.1/relay output) Functional insulation Insulation type (input/supply, analog output/relay output) Functional insulation Functional insulation 500 V Connection data Connection technology Push-in CAGE CLAMP® WAGO Connector picoMAX® 5.0 Solid conductor 0.2 … 2.5 mm² / 24 … 12 AWG Fine-stranded conductor 0.2 … 2.5 mm² / 24 … 12 AWG Strip length 9 … 10 mm / 0.35 … 0.39 inch Physical data Width 22.5 mm / 0.886 inch Height from upper-edge of DIN-rail 107 mm / 4.213 inch Depth 110 mm / 4.331 inch Mechanical data Mounting type DIN-35 rail Material data Fire load 1.796 MJ Weight 149 g Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Temperature range of the connecting cable according to EN 610102-201 ≥ (Tsurrounding air + 25 K) Temperature range of connecting cable per UL 61010-2-201 (min.) 95 °C Relative humidity 5 … 85 % (non-condensing) Operating altitude (max.) 2000 m Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 5/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Operating altitude (max.) 2000 m Standards and specifications Conformity marking CE EMC immunity to interference EN 61000-6-2; EN 61326-2-3 EMC emission of interference EN 61000-6-3; EN 61326-2-3 Standards/Specifications EN 61010-1 UL 61010-1 UL 61010-2-201 Commercial data PU (SPU) 1 Stück Packaging type bag Country of origin DE GTIN 4055143907323 Customs tariff number 85437090300 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-2-201 E175199 Optional accessories Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-141 Micro-WSB-Inline; 2000 pieces on roll; plain; snap-on type; white www.wago.com/2009-141 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-502 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-502 white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 6/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 white Item no.: 793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-503 white Item no.: 793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-504 white Item no.: 793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-505 white Item no.: 793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-506 white Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-566 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; white www.wago.com/793-566 Item no.: 249-116 Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-116 Item no.: 249-117 Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-117 Item no.: 249-197 Screwless end stop; 14 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-197 Mounting Cables and pluggable connectors Item no.: 750-923 Configuration cable; USB connector; Length: 2.5 m www.wago.com/750-923 Item no.: 750-923/000-001 Configuration cable; USB connector; Length: 5 m www.wago.com/750-923 /000-001 Item no.: 281-482 Jumper; insulated; gray www.wago.com/281-482 Item no.: 859-402 Jumper; for jumper slot; 2-way; insulated; light gray www.wago.com/859-402 Item no.: 859-402/000-005 Jumper; for jumper slot; 2-way; insulated; red www.wago.com/859-402 /000-005 Jumpers Item no.: 859-402/000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/859-402 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 7/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Item no.: 859-402/000-006 Jumper; for jumper slot; 2-way; insulated; blue www.wago.com/859-402 /000-006 Item no.: 859-402/000-029 Jumper; for jumper slot; 2-way; insulated; yellow www.wago.com/859-402 /000-029 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Tool General accessories Item no.: 2857-900 Configuration display www.wago.com/2857-900 Item no.: 855-8001 Power tap; with fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); Phase www.wago.com/855-8001 Item no.: 855-8002 Power tap; without fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); N-conductor www.wago.com/855-8002 Item no.: 855-8003 Power tap; with fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); Phase www.wago.com/855-8003 Item no.: 855-8004 Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor www.wago.com/855-8004 Item no.: 855-8006 Power tap; for busbar; with fuse; Mounting screw M6 www.wago.com/855-8006 Item no.: 855-8008 Power tap; for busbar; with fuse; Mounting screw M8 www.wago.com/855-8008 Item no.: 855-8015 Power tap; for busbar; with fuse; Clamping connection www.wago.com/855-8015 Item no.: 857-304 Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 6 A; Yellow status indicator; Module width: 6 mm; 2,50 mm²; gray www.wago.com/857-304 Terminal blocks Item no.: 857-979 Supply and through module www.wago.com/857-979 Power supplies Item no.: 787-2852 Switched-mode power supply; 1-phase; 24 VDC output voltage; 1 A output current; - www.wago.com/787-2852 Testing and measuring Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Downloads Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 8/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Downloads Documentation Instruction Leaflet Single-Phase Power Signal Conditioner; Current and voltage input signal V 2.0.0 Sep 30, 2020 pdf 3.1 MB Download V 1.0.0 pdf 265.8 kB Download URL Download Additional Information Disposal; Electrical and electronic equipment, Packaging Environmental Product Compliance Compliance Search Environmental Product Compliance 2857-569 Single-Phase Power Signal Conditioner; Current and voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC Installation Notes Configuration Configuration via WAGO Interface Configuration Software Configuration via WAGO Configuration Display Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 9/10 Data sheet | Item number: 2857-569 www.wago.com/2857-569 Pluggable connection technology Commoning, not discrete wiring – Same outline allows use of a single in-line, push-in jumper. Safety Lock-out seal option Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 10/10
2857-569 价格&库存
很抱歉,暂时无法提供与“2857-569”相匹配的价格&库存,您可以联系我们找货
