289-172
289-172
    WAGO(万可电子)
    8 接线板 - 接口模块 RJ45 插孔 至 RJ45 插孔
289-172 数据手册
Data sheet | Item number: 289-172 Interface module; RJ-45; RJ-45; Cat. 5; in mounting carrier www.wago.com/289-172 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 05.08.2021    Page 1/3 Data sheet | Item number: 289-172 www.wago.com/289-172 Data Electrical data Operating voltage ≤ AC 30 V; ≤ DC 42 V Nominal current 1.5 A Insulation resistance ≥ 500 MΩ Safety and protection Dielectric strength, contact/contact (AC, 1 min) 1 kVrms Connection data Pole No. 8 Connection type (1) System Pluggable connectors RJ-45 (shielded) Connection type 2 System Pole number 2 8 Connector 2 RJ-45 (shielded) Mating cycles 500 Transmission length (max.) 100 m Connection cable Cat. 5 (min.) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 05.08.2021    Page 2/3 Data sheet | Item number: 289-172 www.wago.com/289-172 Connection cable Cat. 5 (min.) Physical data Width 20.5 mm / 0.807 inch Height 85 mm / 3.346 inch Depth from upper edge of DIN-rail 51 mm / 2.008 inch Mechanical data Mounting type DIN-35 rail Housing design Mounting carrier Material data Fire load 0.492 MJ Weight 28.3 g Environmental requirements Surrounding air temperature (operation) -40 … 85 °C Surrounding air temperature (storage) -40 … 85 °C Surrounding air (operating) temperature for UL -40 … 70 °C Relative humidity  85% (non-condensing) Commercial data Product Group 6 (Interface Electronics) PU (SPU) 15 (1) Stück Packaging type box Country of origin DE GTIN 4045454317478 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 05.08.2021    Page 3/3
289-172 价格&库存
很抱歉,暂时无法提供与“289-172”相匹配的价格&库存,您可以联系我们找货
  • 1+805.398021+104.49664
