721-102/037-000
721-102/037-000
    WAGO(万可电子)
    P=5mm
    1线孔型插头; 2.5 mm2; 焊针间距 5 mm; 2极; 100% 防插错保护; 侧面带有锁定卡; 2,50 mm2; 浅灰色
721-102/037-000 数据手册
Printview: Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only - Item No.: 721-102/037-000 . Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only Item No.: 721-102/037-000 . Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only . Marking . Business data Supplier WAGO Item no. 721-102/037-000 GTIN / EAN 4044918353076 Content 1 Order amount 100 Customer item number . Notes Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationIntegrated test ports100% protected against mismatingCoding option available Technical data Miscellaneous No. of poles 2 Pin Spacing 5 mm / 0.197 in % Total number of connection points 2 Total number of potentials 2 Color light gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only - Item No.: 721-102/037-000 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 16 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 16 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 16 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 2.5 mm² / … Strip length 1 8 … 9 mm / 0.31 … 0.35 in Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 85 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.1 [MJ] Weight [g] 5.214 [g] Width 26.6 mm / 1.047 in Height 14.3 mm / 0.563 in Length 29.6 mm / 1.165 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only - Item No.: 721-102/037-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; with locking levers; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; codable; one latch only - Item No.: 721-102/037-000 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
721-102/037-000 价格&库存
很抱歉,暂时无法提供与“721-102/037-000”相匹配的价格&库存,您可以联系我们找货
