Data sheet from 17.01.2012
Item no.:
733-338
Product description:
HEADER STRAIGHT SOLDER PIN0.8x0.8 MM 8 POLE PIN
SPACING 2.5 MM / 0.098 IN 100% PROTECTED AGAINST
MISMATING MATING DIRECTION PERPENDICULAR TO
PCB WITH CLOSED END
Produkt kann von Bild abweichen / product may differ
Packing unit 200 pieces
RoHS compliant
Weight
1.173 g
Color
light gray
pole count
8
Height
8.9 mm
Height
0.35 in
Width
22.5 mm
Width
0.886 in
Depth
7.8 mm
Depth
0.307 in
Pin spacing from
2.5 mm
Pin spacing from
0.098 in
Pollution degree
2
Measured voltage EN
160 V
Measured shock voltage
2.5 kV
Current intensity EN
6A
Pollution degree
2
Measured voltage EN
1 von 3
320 V
2.5 kV
6A
Material group
I
Contact material
Electrolytic copper (Ecu)
Contact surface
tin-plated
2 von 3
Item no.
Admission office
Approval no.
Voltage [V]
Current [A]
733-338
ABS
04-HG469925/1-PDA
250
4
733-338
BV
11915/A0
250
4
733-338
CCA
NL5640
250
4
733-338
CSA
154112-1465035
150
4
733-338
DNV
E-9218
250
4
733-338
GL
17296-00HH
250
4
733-338
KEMA
2077592.01
250
4
733-338
LR
96/20035
250
6
733-338
RMR
11130002
250
4
733-338
UR
E45171
250
4
733-338
UR
E45172
150
4
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
Cross section [ mm² ]
28-20
28-20
很抱歉,暂时无法提供与“733-338”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.70080
- 10+10.58400
- 30+9.25560
- 200+7.90560
