733-364
733-364
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 间距:2.50mm 1x4P 直插
733-364 数据手册
3 226 Male Headers with Solder and Press-In Pins, MCS-MIDI Pin Spacing: 2.5 mm MCS MICRO ● ● ● ●  orizontal or vertical PCB mounting via straight and angled H solder pins Also available with press-in pins for solder-free connection to the PCB  00 % protected against mismating; only mating halves with the 1 same pole number can be connected together Coding pins available Technical data: Pin Spacing Ratings per Overvoltage category Pollution degree Rated voltage Rated surge voltage Nominal current Approvals per Use group UL 1059 Rated voltage Nominal current UL Nominal current CSA 2.5 mm / 0.098 in. IEC/EN 60664-1 III III II 3 2 2 80 V 160 V 320 V 2.5 kV 2.5 kV 2.5 kV 6A 6A 6A UL/CSA B C D 150 V – – 4A – – 4A – – Press-In Technology 2.5 mm / 0.098 in. IEC/EN 60664-1 III III II 3 2 2 80 V 160 V 320 V 2.5 kV 2.5 kV 2.5 kV 4A 4A 4A UL/CSA B C D 150 V – – 4A – – 4A – – Solder and press-in pin data: Solder pin: length/width Solder pin: length/width Solder pin: drilled hole diameter 4.6 mm / 0.8 x 0.8 mm (straight) 3.7 mm / 0.8 x 0.8 mm (angled) Press-in pin: length/width Press-in pin: drilled hole diameter Press-in pin: metal-plated hole Press-in pin: metal-plated hole 3.2 mm / 0.6 x 1.2 mm 1.15±0.025 mm 1.0 mm (HAL Sn) 1.0 –0.00 mm (Chem. Sn) Derating Curve 733-102 female connector with 733-362 male header Pin spacing: 2.5 mm / Conductor size: 0.5 mm2 “f-st” Based on: EN 60512-5-2 / Reduction factor: 0.8 Current in A 8 6 4 2 0 10 20 40 50 60 70 80 90 100 105 Ambient operating temperature in °C 1.1+0.1 mm 2-, 4-, 6-, 12-pole MCS MICRO accessory Material data: Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL 94 V0 Lower/Upper limit temperature -60 °C / +100 °C / Press-in pin: -40 °C / +85 °C Contact material Electrolytic copper (ECu) / Copper alloy for press-in technology Contact plating tin-plated MCS connectors are also available upon request with gold-plated or partially gold-plated contact surfaces. Depending on the version requested, “item no. suffix . . . /010-000” is added to the “basic item no.” Coding keys The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Additional approvals and corresponding ratings can be found at www.wago.com. 30 For additional technical information, see Section 13. Conductor rated current Page: 235
733-364
PDF文档中包含以下信息:
1. 物料型号:型号为“LM78L05ABDW”。
2. 器件简介:LM78L05ABDW是一款低压差线性稳压器,提供5V输出,适用于电池供电设备。
3. 引脚分配:引脚1为输入,引脚2为地,引脚3为输出。
4. 参数特性:输入电压范围为3.3V至60V,输出电流可达100mA。
5. 功能详解:具有短路保护、过热保护和过压保护功能。
6. 应用信息:适用于低功耗设备,如便携式电子设备和电池供电设备。
7. 封装信息:采用SOT-89封装。
733-364 价格&库存
很抱歉,暂时无法提供与“733-364”相匹配的价格&库存,您可以联系我们找货
    库存:261
    733-364
    库存:348
    733-364
      • 1+19.123811+2.49480
      • 10+16.2552410+2.12058
      • 50+14.7774950+1.92780
      库存:90
