Data sheet | Item number: 734-148
THT male header; 1.0 x 1.0 mm solder pin; straight; 100% protected against
mismating; Pin spacing 3.5 mm; 18-pole; light gray
www.wago.com/734-148
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
21.06.2021 Page 1/8
L = (pole no. – 1) x pin spacing + 5.9 mm
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
100% protected against mismating; only mating halves with the same number of poles can be connected together
Coding option available
Safety information 1:
The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as
intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can
be touched, are not live when unmated.
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Hansastr. 27
32423 Minden
21.06.2021 Page 2/8
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Pole No.
18
Total number of potentials
18
Number of connection types
1
Number of levels
1
Physical data
Pin spacing
3.5 mm / 0.138 inch
Width
65.4 mm / 2.575 inch
Height
14.8 mm / 0.583 inch
Height from the surface
10.3 mm / 0.406 inch
Depth
8.5 mm / 0.335 inch
Solder pin length
4.5 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter with tolerance
1.4 (+0.1) mm
Hansastr. 27
32423 Minden
21.06.2021 Page 3/8
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
90 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
1
Material data
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.067 MJ
Weight
4 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918847773
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Approval
Additional Approval Text
Hansastr. 27
32423 Minden
Certificate
21.06.2021 Page 4/8
Approval
Certificate
name
CCA
DEKRA Certification B.V.
EN 61984
2169534.02
CCA
EN 61984
nl-54190
CSA
C22.2
1465035
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
LR
Lloyds Register
IEC 61984
96/20035
(E5)
Logo
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Certificate
name
Approval
UL
UL International Germany GmbH
UL 1977
20150318E45171
UR
Underwriters Laboratories Inc.
UL 1059
E4517219950922
Hansastr. 27
32423 Minden
21.06.2021 Page 5/8
Counterpart
Item no.734-118
1-conductor female connector; 100% protected against mismating; 1.5 mm²; Pin spacing 3.5 mm; 18pole; 1,50 mm²; light gray
www.wago.com/734-118
Item no.2734-118
1-conductor female connector; 100% protected against mismating; push-button; 1.5 mm²; Pin spacing www.wago.com/2734-118
3.5 mm; 18-pole; 1,50 mm²; light gray
Item no.2734-118/027-000
1-conductor female connector; 100% protected against mismating; push-button; clamping collar; 1.5
mm²; Pin spacing 3.5 mm; 18-pole; 1,50 mm²; light gray
/027-000
Item no.2734-118/037-000
1-conductor female connector; 100% protected against mismating; push-button; Locking lever; 1.5
/037-000
Item no.734-118/037-000
1-conductor female connector; 100% protected against mismating; Locking lever; 1.5 mm²; Pin
/037-000
Item no.734-118/037-000/036-000
1-conductor female connector; 100% protected against mismating; Locking lever; Strain relief plate;
1.5 mm²; Pin spacing 3.5 mm; 18-pole; 1,50 mm²; light gray
/037-000/036-000
Optional accessories
Coding
Item no.: 734-130
Coding key; to be snapped above top level; white
www.wago.com/734-130
Item no.: 734-159
Coding key; to be snapped above top level; black
www.wago.com/734-159
Downloads
Documentation
Additional Information
Technical explanations
2019 Apr 3
pdf
2.0 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models
734-148
Subject
to changes.
Hansastr. 27
32423 Minden
21.06.2021 Page 6/8
2D/3D Models 734-148
URL
Download
EPLAN Data Portal 734-148
URL
Download
ZUKEN Portal 734-148
URL
Download
URL
Download
CAE data
PCB Design
Symbol and Footprint 734-148
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental
Product Compliance
Hansastr. 27
32423 Minden
21.06.2021 Page 7/8
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 734-148
URL
Download
Installation Notes
Coding a male header – fitting coding key(s).
Product family
MCS MINI
Show all products from the family
Hansastr. 27
32423 Minden
21.06.2021 Page 8/8
很抱歉,暂时无法提供与“734-148”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+80.662501+10.41286
- 10+68.5540510+8.84976
- 100+58.26576100+7.52162
- 500+52.01464500+6.71466
- 1000+49.534851000+6.39454
