734-162
734-162
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.50mm 1x2P 直插
734-162 数据手册
Data sheet from 22.01.2013 Item no.: 734-162 Product description: HEADER RIGHT ANGLE SOLDER PIN, 1 X 1 MM / 0.039 X 0.039 IN 2 POLE PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CLOSED END MATING DIRECTION PARALLEL TO PCB Produkt kann von Bild abweichen / product may differ Packing unit 200 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 0.648 g Color light gray pole count 2 Height 8.5 mm Height 0.335 in Width 9.4 mm Width 0.37 in Depth 10.3 mm Depth 0.406 in Pin spacing from 3.5 mm Pin spacing from 0.138 in Pollution degree 2 Measured voltage EN 160 V Measured shock voltage 2.5 kV Current intensity EN 10 A Pollution degree 1 von 3 2 Measured voltage EN 320 V Measured shock voltage 2.5 kV Current intensity EN 10 A Material group I Contact material Electrolytic copper (Ecu) Contact surface tin-plated 2 von 3 Data sheet from 22.01.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 734-162 ABS 04-HG469925/1-PDA 250 10 0,5-1,5 734-162 BV 11915/A0 250 10 0,5-1,5 734-162 CCA NL5641 250 10 0,5-1,5 734-162 CSA 154112-1465035 300 10 28-14 734-162 DNV E-9218 250 10 0,5-1,5 734-162 GL 17296-00HH 250 10 0,5-1,5 734-162 KEMA 2077592.02 250 10 0,5-1,5 734-162 LR 96/20035 250 10 0,5-1,5 734-162 RMR 11130002 250 10 0,5-1,5 734-162 UR E45171 250 10 28-14 734-162 UR E45172 300 10 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
734-162 价格&库存
很抱歉,暂时无法提供与“734-162”相匹配的价格&库存,您可以联系我们找货
    • 1000+1.62950
    库存:908
    734-162
      • 1+1041.38371
      库存:200
      734-162
      • 1+12.284051+1.58843
      • 10+10.3921610+1.34379
      • 100+8.78400100+1.13585
      • 500+5.75266500+0.74387
      • 1000+5.435021000+0.70280
      • 5000+4.940205000+0.63881
      • 10000+4.7175310000+0.61002
      库存:1739
      734-162
      • 16+10.5540316+1.36473
      • 100+8.92105100+1.15357
      • 500+5.84244500+0.75548
      • 1000+5.520071000+0.71379
      • 5000+5.017445000+0.64880
      • 10000+4.7908810000+0.61950
      库存:1734
