Pluggable Thermal Circuit Breakers
and Compatible Terminal Blocks
DIN Rail Mount Pluggable
DIN rail mount pluggable miniature thermal circuit breakers are used for protection of power
distribution systems, automation systems, and process control applications. The wide variety
of circuit breakers has unique characteristics that tailor to the needs and performance
of many different applications.
The compatible WAGO carrier terminal block uses CAGE CLAMP® connection technology,
reducing wiring time and providing connections that are corrosion-resistant, temperature cycling
resistant & maintenance-free. An excellent alternative to traditional fusing methods.
Miniaturized Thermal Automotive Circuit Breaker
Product width: 9.8 mm
On-off switch
Typical time/current
characteristics at +23 °C/+73.4 °F
Description
Item No. Units
20 A, 28 VDC
51014339
15 A, 28 VDC
25 A, 28 VDC
51014338
1
51014340
1
10000
+60 °C
+124 °F
1
+23 °C
+73.4 °F
Technical Data
Voltage Rating
DC 28 V
Current Ratings
3 ... 25 A (30 A upon request)
Typical Life
6,000 operations at IN
3,000 operations at 2 x IN ≤ 20 A
1,000 operations at 2 x IN 25 A
Ambient Remperature
-30...+60 °C (-22...140 °F)
Vibration
3 or 4 A: 8 g (57-500 Hz) ±0.65 mm (10-57 Hz)
5...25 A: 10 g (57-500 Hz) ±0.76 mm (10-57 Hz)
to IEC 60068-2-6, test Fc,10 frequency cycles/axis
trip time in seconds
1000
-30 °C
-22°F
100
10
1
3 or 4 A: 35 g (11 ms)
Shock
5...25 A: 50 g (11 ms)
to IEC 60068-2-27, test EA
Corrosion
96 hours at 5% salt mist,
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95% RH to IEC 60068-2-3, test Ca
0.1
1
2
4
6
multiplied by rated current
8 10
Description
Product width: 8.2 mm
On-off switch; Plug-in type
250 VAC
65 VDC
51216518
1
0.25 A
250 VAC
65 VDC
51012494
1
0.50 A
250 VAC
65 VDC
51012495
1
1.0 A
250 VAC
65 VDC
60415643
1
2.0 A
250 VAC
65 VDC
60494163
1
3.0 A
250 VAC
65 VDC
51012498
1
4.0 A
250 VAC
65 VDC
51012499
1
5.0 A
250 VAC
65 VDC
51012500
1
6.0 A
250 VAC
65 VDC
51012501
1
7.0 A
250 VAC
65 VDC
51014523
1
8.0 A
250 VAC
65 VDC
51012502
1
10.0 A
250 VAC
65 VDC
51012503
1
Voltage Rating
AC 250 V; DC 65 V
Current Ratings
0.1...10 A
Typical Life
3,000 operations at 1 x IN
Rated Voltage
(low-resistive)
500 operations at 2 x IN (inductive)
Ambient Temperature
-20...+60 °C (T 60) -4...+140 °F
Insulation Co-Ordination
(IEC 60664 and 60664A)
Units
0.10 A
Rated Impulse
Withstand Voltage
Pollution Degree
2.5 kV
2
Reinforced insulation
in operating area
Insulation Resistance
>100 MΩ (DC 500 V)
Interrupting Capacity
AC 250 v 2,000 A
(UL 1077)
DC 65 V: 200 A
Vibration
5 g (57-500 Hz) ±0.38 mm (10-57Hz)
AC 250 V: 2,000 A
Shock
25 g (11 ms)
to IEC 60068-2-27, test Ea
Corrosion
Humidity
240 hours at 95% RH
10000
0.1 - 5 A
1000
6 - 10 A
Technical Data
Item No.
100
10
1
0.1
1
2
4
6
8 10
Description
Item No.
Units
20 A, 28 VDC
51014617
1
25 A, 28 VDC
60404900
1
30 A, 28 VDC
60404899
1
15 A, 28 VDC
60404858
1
Product width: 6 mm
Standard fuse block mounting
Color housing
10000
Technical Data
DC 32 V
Current Ratings
6 ... 30 A
Service Short-Circuit
Breaking Capacity
300 operations at ≤ 50 A
Ambient temperature
Ultimate Short-Circuit
Breaking Capacity
≥ 3 break operations at 150 A, or
1 break operation at 2,000 A
Vibration
(with mounting socket 12)
5 g (57-500 Hz) ±0.38mm (10-57 Hz)
to IEC 60068-2-6, Test Fc,
Shock
(with mounting
socket 12)
25 g (11 ms)
to IEC 60068-2-27, Test EA
Corrosion
96 hours at 5% salt mist, to
Humidity
Modular design allows
for combination of
breakers, fuses, and
disconnect terminal
blocks in the same
footprint.
+23 °C
+73.4 °F
1000
Voltage Rating
+60 °C
+140 °F
-30 °C
-22 °F
100
10
1
0.1
1
2
4
6
8 10
Compatible terminal
blocks in both WAGO
Classic & TOPJOB® S
terminal block families.
Easy commoning
via push-in jumpers.
Test slots are available
on both sides of the
terminal for direct
measurement.
Type
TOPJOB® S
Automotive
Fuse or Circuit
Breakers
Series Part Number
2006-1681
Width
Cross
Section
V/A Ratings
7.5mm*
20-8
AWG
30 A/600 V
2006-1681/xxx-xxx
2006
Various UL
rated versions
available
ACESSORIES
Series
End & Intermediate
Plate
Push-In Type
Jumper Bar
(insulated)
Acessory Description
2006
2006
Width
2006-1691
gray
2006-1692
orange
2006-402
2-way; light gray
2006-403
3-way; light gray
2006-404
4-way; light gray
2006-405
5-way; light gray
2006-433
1 to 3; light gray
2006-434
1 to 4; light gray
V/A Ratings
1mm
IN 41 A
IN 41 A
2006-435
1 to 5; light gray
Marking Solutions
Type
TOPJOB® S Classic
Automotive Fuse
or Circuit Breakers
2009-110
Continuous Strip
2009
2009-115
WMB Inline
Series Part Number
282-696
282
for jumper slots are
available for
TOPJOB® S family
Marked with
SmartPRINTER
(custom & pre-printed
marker cards
also available)
11mm;
5.2mm
Width
Cross
Section
8mm*
24-10
AWG
282-698/281-xxx**
Test plug adapters
& modular connectors
V/A Ratings
30 A/600 V
Various UL
rated versions
available
ACESSORIES
Series
Width
End Plate
282
282-334
gray
282-333
orange
Adjacent Jumper
(insulated)
282
282-402
gray
282-422
yellow-green
Alternate Jumper
(insulated)
282
282-409
gray
Test Plug Adapter
(for 4mm ∅ plug;
for 1.5 ... 10 mm2
terminal blocks)
209
209-170
gray
8.3mm
B-Type Test Plug
Module
(snaps together)
709
709-310
gray
8mm
2009
2009-115
WMB Inline
Marking Solutions
V/A Ratings
2mm
IN 41 A
IN 41 A
5.2mm
* May require end plate for use with pluggable circuit breakers. (Take note of terminal block width and circuit breaker width.)
** Available with indication; contact factory for part number suffix.
(1) The electrical data is defined by the fuse and blown fuse indication respectively.
Marked with
SmartPRINTER
marker cards
also available)
很抱歉,暂时无法提供与“8000-099/000-3108”相匹配的价格&库存,您可以联系我们找货
