2000-1205
2000-1205
    WAGO(万可电子)
    Conn Feed-Through Terminal Block 2 POS Spring Clamp DIN Rail 15A Box
2000-1205 数据手册
Data sheet  |  Item number: 2000-1205 2-conductor through terminal block; 1 mm²; suitable for Ex e II applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,00 mm²; black www.wago.com/2000-1205 Color: Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 800 V Rated surge voltage (III/3) 8 kV Rated current 13.5 A Rated current 2 17.5 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 15 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 1/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 15 A Approvals per CSA Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 10 A Approvals Ex Rated voltage EN (Ex e II) 550 V Rated current (Ex e II) 13 A Rated current (Ex e II) with jumper 12 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross-section 1 mm² Solid conductor 0,14 … 1,5 mm² / 24 … 16 AWG Solid conductor; push-in termination 0,5 … 1,5 mm² / 20 … 16 AWG Fine-stranded conductor 0,14 … 1,5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0,5 … 0,75 mm² / 20 … 18 AWG Fine-stranded conductor; with ferrule; push-in termination 0,5 … 0,75 mm² / 20 … 18 AWG Strip length 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring type Front-entry wiring Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Number of jumper slots 2 Geometrical Data Width 3,5 mm / 0.138 inch Heightto from upper-edge DIN-rail Subject changes. Pleaseof also observe the further product documentation!32,9 mm / 1.295 inch WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 2/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Width 3,5 mm / 0.138 inch Height from upper-edge of DIN-rail 32,9 mm / 1.295 inch Depth 48,5 mm / 1.909 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material Data Color black Insulation material Polyamide 66 (PA 66) Fire load 0.079 MJ Weight 3.6 g Commercial data Packaging type BOX Country of origin CN GTIN 4045454966805 Customs tariff number 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN 60079 PTB 11 ATEX 1041 U (II 2 G Ex e IIC GB / I M 2 Ex e I Mb) IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 11.0093U Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com (Ex e IIC Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 3/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 (Ex e IIC Gb or Ex e I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 71102841 CSA DEKRA Certification B.V. C22.2 No. 158 2130762 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 RU C-DE. AM02.B. 00127/19 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA BV Bureau Veritas S.A. EN 60947 38586/A0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL 1059 20190930- UL International Germany GmbH Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com E45172 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 4/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 UL International Germany GmbH E45172 Counterpart Compatible products Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-113 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white www.wago.com/2009-113 Item no.: 2009-113/000-002 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow www.wago.com/2009-113 /000-002 Item no.: 2009-113/000-005 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red www.wago.com/2009-113 /000-005 Item no.: 2009-113/000-006 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue www.wago.com/2009-113 /000-006 Item no.: 2009-113/000-007 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray www.wago.com/2009-113 /000-007 Item no.: 2009-113/000-012 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange www.wago.com/2009-113 /000-012 Item no.: 2009-113/000-017 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green www.wago.com/2009-113 /000-017 Item no.: 2009-113/000-023 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-113 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 5/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Item no.: 2009-113/000-023 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green www.wago.com/2009-113 /000-023 Item no.: 2009-113/000-024 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet www.wago.com/2009-113 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 793-3501 WMB marking card; as card; plain; snap-on type; white www.wago.com/793-3501 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-647 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 2000-402 Jumper; 2-way; insulated; light gray www.wago.com/2000-402 Item no.: 2000-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2000-402 /000-005 Item no.: 2000-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2000-402 /000-006 Item no.: 2000-402/000-018 Jumper; 2-way; insulated; yellow-green www.wago.com/2000-402 /000-018 Item no.: 2000-403 Jumper; 3-way; insulated; light gray www.wago.com/2000-403 Item no.: 2000-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2000-403 /000-005 Item no.: 2000-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2000-403 /000-006 Item no.: 2000-404 Jumper; 4-way; insulated; light gray www.wago.com/2000-404 tools Jumper Item no.: 2000-404/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2000-404 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 6/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Item no.: 2000-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2000-404 /000-005 Item no.: 2000-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2000-404 /000-006 Item no.: 2000-405 Jumper; 5-way; insulated; light gray www.wago.com/2000-405 Item no.: 2000-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2000-405 /000-005 Item no.: 2000-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2000-405 /000-006 Item no.: 2000-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2000-405 /011-000 Item no.: 2000-406 Jumper; 6-way; insulated; light gray www.wago.com/2000-406 Item no.: 2000-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2000-406 /000-005 Item no.: 2000-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2000-406 /000-006 Item no.: 2000-406/020-000 Delta jumper; insulated; light gray www.wago.com/2000-406 /020-000 Item no.: 2000-407 Jumper; 7-way; insulated; light gray www.wago.com/2000-407 Item no.: 2000-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2000-407 /000-005 Item no.: 2000-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2000-407 /000-006 Item no.: 2000-408 Jumper; 8-way; insulated; light gray www.wago.com/2000-408 Item no.: 2000-408/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 7/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Item no.: 2000-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2000-408 /000-005 Item no.: 2000-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2000-408 /000-006 Item no.: 2000-409 Jumper; 9-way; insulated; light gray www.wago.com/2000-409 Item no.: 2000-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2000-409 /000-005 Item no.: 2000-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2000-409 /000-006 Item no.: 2000-410 Jumper; 10-way; insulated; light gray www.wago.com/2000-410 Item no.: 2000-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2000-410 /000-005 Item no.: 2000-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2000-410 /000-006 Item no.: 2000-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2000-433 Item no.: 2000-433/000-005 Jumper; from 1 to 3; insulated; red www.wago.com/2000-433 /000-005 Item no.: 2000-433/000-006 Jumper; from 1 to 3; insulated; blue www.wago.com/2000-433 /000-006 Item no.: 2000-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2000-434 Item no.: 2000-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2000-435 Item no.: 2000-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2000-436 Item no.: 2000-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2000-437 Item no.: 2000-438 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2000-438 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 8/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Item no.: 2000-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2000-438 Item no.: 2000-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2000-439 Item no.: 2000-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2000-440 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 209-190 Separator for Ex e/Ex i applications; 3 mm thick; 90 mm wide; orange www.wago.com/209-190 Item no.: 209-191 Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange www.wago.com/209-191 End plate Push-In type wire jumper Item no.: 2009-402 Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray www.wago.com/2009-402 Item no.: 2009-404 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray www.wago.com/2009-404 Item no.: 2009-406 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray www.wago.com/2009-406 Item no.: 2000-510 TOPJOB®S L-type test plug module; modular; for jumper contact slot; 1,00 mm²; gray www.wago.com/2000-510 Item no.: 2000-511 TOPJOB®S L-type test plug module; modular; for jumper contact slot; 1-pole; 1,00 mm²; gray www.wago.com/2000-511 Item no.: 2000-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2000-549 Item no.: 2000-552 Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 1,00 mm²; gray www.wago.com/2000-552 Item no.: 2000-553 Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 1,00 mm²; gray www.wago.com/2000-553 Item no.: 2000-554 Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 1,00 mm²; gray www.wago.com/2000-554 Item no.: 2000-555 Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 1,00 mm²; gray www.wago.com/2000-555 check Item no.: 2000-556 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 9/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Item no.: 2000-556 Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 1,00 mm²; gray www.wago.com/2000-556 Item no.: 2000-557 Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 1,00 mm²; gray www.wago.com/2000-557 Item no.: 2000-558 Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 1,00 mm²; gray www.wago.com/2000-558 Item no.: 2000-559 Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 1,00 mm²; gray www.wago.com/2000-559 Item no.: 2000-560 Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 1,00 mm²; gray www.wago.com/2000-560 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Carrier rail Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver- www.wago.com/210-196 colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copper-colored www.wago.com/210-198 Protective Warning Marker Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 10/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Protective Warning Marker Item no.: 2000-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2000-115 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 ferrule Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-242 crimped; acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Downloads Documentation Bid Text 2000-1205 Feb 19, 2019 xml 4.0 kB Download Aug 7, 2018 docx 14.8 kB Download URL Download EPLAN Data Portal 2000-1205 URL Download WSCAD Universe 2000-1205 URL Download ZUKEN Portal 2000-1205 URL Download GAEB X81 - Datei 2000-1205 GAEB docx - Datei CAD/CAE-Data CAD data 2D/3D Models 2000-1205 CAE data Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 11/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 All conductor types at a glance Terminating solid and ferruled conductors via push-in connection. Inserting conductors via push-in termination. Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 12/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Inserting a conductor via operating tool. Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. The smart feature: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 13/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar. Insert the operating tool between the jumper and and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Commoning This star point jumper has been specially developed to create a “star point” and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. This delta jumper has been specially developed to create a delta configuration and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. Push down the wire jumper (2009‑402) until fully inserted. Lift the jumper with an operating tool for rewiring. Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 14/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 The modular TOPJOB® S connectors also connect conductors of the same size as the terminal blocks being used. TOPJOB® S Connectors with a 2 mm Ø test socket for testing voltage via 2-pole voltage tester Test plug adapter (2009‑174, CAT I) for 4 mm Ø plugs – compatible with 2000 to 2016 Series Testing tap (2009‑182) for tool-free connection of test cables up to 2.5 mm² (12 AWG) – compatible with 2000 to 2016 Series Rail-mount terminal block assembly for electric motor wiring Marking Snapping WMB Inline markers into marker slots. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 15/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 TOPJOB® S 2009‑193 Group Marker Carrier (equipped with a marking strip) for all 2001 to 2016 Series TOPJOB® S Rail-Mount Terminal Blocks Do not use on an end plate! Through terminal blocks with a blue insulated housing are suitable for Ex i applications. All through and ground conductor terminal blocks are suitable for Ex e II applications. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 16/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 Separator for Ex e/Ex applications Ex e II/Ex i terminal strip An end plate must be applied to the terminal block located directly behind an Ex e/Ex i separator plate. Notice: Separator located between Ex e II and Ex i terminal strip The movable feet of terminal blocks and separator plates must face the same direction. End plate Ex e II terminal blocks Separator for Ex e/Ex i applications End plate Ex i terminal blocks According to EN 50020, a minimum distance of 50 mm must be kept between live parts of Ex e and Ex i circuits. The use of Ex e/Ex i separators is a space-saving solution when Ex e and Ex i terminal blocks are mounted on a common carrier rail. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railSubject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 17/18 Data sheet  |  Item number: 2000-1205 www.wago.com/2000-1205 TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 18/18
2000-1205 价格&库存
很抱歉,暂时无法提供与“2000-1205”相匹配的价格&库存,您可以联系我们找货
  • 1+33.080151+4.29962
  • 10+23.5892110+3.06603
  • 25+20.6246925+2.68071
  • 50+18.7634150+2.43879
  • 100+17.21619100+2.23769
  • 250+15.60432250+2.02818
  • 500+14.66410500+1.90598
  • 1000+13.921411000+1.80945
  • 5000+12.765705000+1.65923
库存:19
2000-1205
    • 1+1413.03273
    库存:610
    2000-1205
      • 1+193.61406
      库存:610
