Printview: 2-conductor fuse terminal block for mini-automotive blade-style fuses; with test option; without
blown fuse indication - Item No.: 2006-1681
fuses; with test option; without blown fuse indication
Item No.: 2006-1681
2-conductor fuse terminal block for mini-automotive blade-style fuses; with test option; without blown fuse indication
Marking
Business data
Supplier
WAGO
Item no.
2006-1681
GTIN / EAN
4050821181729
Content
1
Order amount
25
Customer item number
Notes
Safety information 2: Blade-style fuses, please note touchproof protection for 42V and higher.
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
2
Color
gray
Ratings according to 1
IEC/EN 60947-7-3
Pollution degree (1)
3
Rated voltage EN (1) [V]
500 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
25 [A]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Nominal current (2) [A]
30 [A]
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
6 mm²
Solid sizes 1
0.5 … 10 mm² / 20 … 8 AWG
solid, directly pluggable 1
1 … 10 mm² / 14 … 8 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 1.5 mm² / 16 AWG
Strip length 1
13 … 15 mm / 0.51 … 0.59 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.275 [MJ]
Weight [g]
16.275 [g]
Width
7.5 mm / 0.295 in
Height from upper-edge of DIN-rail [mm]
32.9 [mm]
32.9 mm / 1.295 in
Length
96.3 mm / 3.791 in
Type of mounting
DIN 35 rail
Safety information 1
Electrical ratings are given by the fuse.
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2006-1681”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+187.215744+24.33744
- 10+163.4888210+21.25302
- 26+117.0200726+15.21223
- 50+115.2634150+14.98387
- 国内价格
- 1+203.47289
- 10+145.64288
- 100+79.48364
- 250+77.90559
- 500+76.31568
- 1000+74.72577
