2006-931/1000-836
2006-931/1000-836
    WAGO(万可电子)
    Fuse Plug 10A 800V Socket Lug Box ; Region : ACNA
2006-931/1000-836 数据手册
Printview: Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 230 V; 7.4 mm wide - Item No.: 2006-931/1000-836 . Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 230 V; 7.4 mm wide Item No.: 2006-931/1000-836 . Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 230 V; 7.4 mm wide . Marking . Business data Supplier WAGO Item no. 2006-931/1000-836 GTIN / EAN 4045454821081 Content 1 Order amount 25 Customer item number . Notes Safety information 1: Electrical ratings are given by the fuse and blown fuse indication. Technical data Miscellaneous Color gray Rated voltage EN (1) [V] 800 [V] Nominal current [A] 10 [A] Marking level Center marking Weight [g] 6.422 [g] Width 7.4 mm / 0.291 in Safety information 2 Leakage current in case of blown fuse: LED 2mA WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 230 V; 7.4 mm wide - Item No.: 2006-931/1000-836 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 230 V; 7.4 mm wide - Item No.: 2006-931/1000-836 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
2006-931/1000-836 价格&库存
很抱歉,暂时无法提供与“2006-931/1000-836”相匹配的价格&库存,您可以联系我们找货
2006-931/1000-836
  • 1+220.719931+28.69967
  • 10+187.6039510+24.39368
  • 25+175.8563925+22.86618
  • 50+167.4635150+21.77487
  • 100+159.47530100+20.73618
  • 250+149.50115250+19.43927
  • 500+142.37548500+18.51274
库存:3
