2060-954/028-000
2060-954/028-000
    WAGO(万可电子)
    WAGO - 2060-954/028-000 - Accessory, 4 Pole, Wago 2060 Series PCB & Pluggable Terminal Blocks, Board...
2060-954/028-000 数据手册
Data sheet  |  Item number: 2060-954/028-000 Board-to-Board Link; Pin spacing 4 mm; 4-pole; Length: 28 mm; white www.wago.com/2060-954/028-000 Color: Item description Board-to-board link simplifies in-line assembly of LED modules Easy push-in termination and disconnection without push-button actuation Recommendation: Only suitable for 2060-45x, not for 2060-40x. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 63 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V 25.09.2019    Page 1/4 Data sheet  |  Item number: 2060-954/028-000 www.wago.com/2060-954/028-000 Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) 2.5 kV Rated current 9  A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 250 V Rated current per UL 1977 (factory wiring only) 9  A Connection data Total number of potentials 4 Number of connection types 1 No. of poles 4 Geometrical Data Pin spacing 4 mm / 0.157 inch Width 15.4 mm / 0.606 inch Height 2.6 mm / 0.102 inch Depth 28 mm / 1.102 inch Mechanical data Mating cycles 10 Number of mating cycles max. 10 mating cycles Suitable forSMD PCB Terminal Blocks with Push-button Material Data Color white Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating silver-plated Weight 0.93 g Environmental Requirements Limit temperature range -60 … +105 °C 25.09.2019    Page 2/4 Data sheet  |  Item number: 2060-954/028-000 www.wago.com/2060-954/028-000 Commercial data Country of origin CN GTIN 4055143303842 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7724 CCA DEKRA Certification B.V. EN 60998 NTR NL 7725 CCA DEKRA Certification B.V. EN 60838 NTR NL 2168246 KEMA/KEUR DEKRA Certification B.V. EN 60838 2168246.01 KEMA/KEUR DEKRA Certification B.V. EN 60947 71-108183 KEMA/KEUR DEKRA Certification B.V. EN 60998 71-108181 UL-Approvals Logo Approval Additional Approval Text cURus Underwriters Laboratories Inc. UL 1977 Certificate name E4517120111005 25.09.2019    Page 3/4 Data sheet  |  Item number: 2060-954/028-000 www.wago.com/2060-954/028-000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 3D Download 2060-954/028-000   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 25.09.2019    Page 4/4
2060-954/028-000 价格&库存
很抱歉,暂时无法提供与“2060-954/028-000”相匹配的价格&库存,您可以联系我们找货
  • 1+15.955041+2.06808
