Data sheet | Item number: 2061-1662/998-404
THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 6 mm; 2-pole;
Push-in CAGE CLAMP®; in tape-and-reel packaging; 1,50 mm2; black
www.wago.com/2061-1662/998-404
Color:
R = Feed direction
24.09.2019 Page 1/6
Item description
THR PCB terminal blocks with push-buttons and Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Push-buttons simplify insertion/removal of all conductor types
Just 5.6 mm tall
Available in tape-and-reel packaging for automated assembly
Also suitable for wave soldering
Assemble terminal blocks without pole loss
Note:
Application note:
Suitable for lead-free, reflow-soldering profiles per DIN EN 61760-1 and IEC 60068-2-58 up to max.
260 °C peak temperature. Due to customer-specific variables (e.g., component configuration and orientation, type of soldering machine, solder
paste), trial runs are recommended to ensure product and process compatibility under actual manufacturing conditions.
Recommendation:
Recommendation for stencil:
150 µm material thickness
The stencil hole diameter is identical to the outer diameter of the metal-plated PCB hole.
Data
Electrical data
Ratings per IEC/EN 60664-1
24.09.2019 Page 2/6
Rated voltage (III / 3)
250 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
17.5 A
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.5 … 0.75 mm²
Fine-stranded conductor with ferrule without plastic collar
0.5 … 0.75 mm²
Strip length
7 … 10 mm / 0.28 … 0.39 inch
Conductor entry angle to the PCB
0 °
Total number of connection points
2
Total number of potentials
2
Number of connection types
1
Number of levels
1
No. of poles
2
Geometrical Data
Pin spacing
6 mm / 0.24 inch
Width
11.7 mm / 0.461 inch
Height
7.1 mm / 0.28 inch
Height from the surface
5.6 mm / 0.22 inch
Depth
15.2 mm / 0.598 inch
Solder pin length
1.5 mm
Solder pin dimensions
1.2 x 0.35 mm
Reel diameter of tape-and-reel packaging
330 mm
Tape width
24 mm
24.09.2019 Page 3/6
PCB contact
PCB contact
THR
Solder pin arrangement
over the entire terminal strip, in line
Number of solder pins per potential
2
Material Data
Color
black
Material group
I
Insulating material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Weight
1.047 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Country of origin
CH
GTIN
4055143274685
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947-7-4
NTR NL7459
CCA
EN 60838
NTR NL7721
KEMA/KEUR
EN 60947-7-4
71100855
KEMA/KEUR
EN 60838
71106232
24.09.2019 Page 4/6
UL-Approvals
Logo
Approval
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1059
E45172
Compatible products
tools
Item no.: 2061-189
Operating tool; made of insulating material; for 2061 Series
www.wago.com/2061-189
Item no.: 206-861
Operating tool; for 2061 Series
www.wago.com/206-861
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-262
www.wago.com/216-262
ferrule
24.09.2019 Page 5/6
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
3D Download 2061-1662/998-404
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
24.09.2019 Page 6/6
很抱歉,暂时无法提供与“2061-1662/998-404”相匹配的价格&库存,您可以联系我们找货
