Data sheet | Item number: 2075-381/997-404
Through-Board SMD PCB Terminal Block; Pin spacing 3 mm; 1-pole; PUSH
WIRE®; in tape-and-reel packaging; Without housing; 0,75 mm2
www.wago.com/2075-381/997-404
Item description
For vertical wiring
Wiring performed on the back of the LED module simplifies lighting manufacturing
Low installation height minimizes on-board LED shadowing
Compact design provides uniform light distribution
An economical alternative to wire soldering
For manual and automated wiring systems
05.09.2019 Page 1/4
Note:
Klemme ohne Isolationsgehäuse!
Der Berührungsschutz beim Einsatz von Spannungen größer als Kleinspannungen, wie z. B. SELV/PELV, ist in der Anwendung sicherzustellen.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
200 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (II / 2)
500 V
Rated impulse voltage (II / 2)
4 kV
Rated current
9 A
Connection data
Connection technology
PUSH WIRE®
Actuation type
Push-in
Solid conductor
0.34 … 0.75 mm² / 20 … 18 AWG
Strip length
3.7 mm / 0.15 inch
Conductor entry angle to the PCB
90 °
Total number of connection points
1
Total number of potentials
1
Number of connection types
1
Number of levels
1
No. of poles
1
Geometrical Data
Width
3 mm / 0.118 inch
Height
3.9 mm / 0.154 inch
Depth
17.5 mm / 0.689 inch
Reel diameter of tape-and-reel packaging
330 mm
Tape width
24 mm
PCB contact
PCB contact
SMD
Material Data
05.09.2019 Page 2/4
Material Data
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
0.16 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Country of origin
CH
GTIN
4055143607636
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
KEMA/KEUR
DEKRA Certification B.V.
EN 60998
Approval
cURus
Underwriters Laboratories Inc.
UL 1977
Certificate
name
71107567
UL-Approvals
Logo
Certificate
name
E45171
Sec. 24
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
05.09.2019 Page 3/4
CAD/CAE-Data
CAD data
3D Download 2075-381/997-404
URL
Download
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
05.09.2019 Page 4/4
很抱歉,暂时无法提供与“2075-381/997-404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.675752000+0.34683
