Printview: Compact splicing connector; 3-conductor terminal block; with operating levers; max. continuous
service temperature 85°C - Item No.: 222-413
operating levers; max. continuous service temperature 85°C
Item No.: 222-413
Compact splicing connector; 3-conductor terminal block; with operating levers; max. continuous service temperature
85°C
Marking
Business data
Supplier
WAGO
Item no.
222-413
GTIN / EAN
4017332955676
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
3
Total number of potentials
1
Color
gray
Pollution degree (1)
2
Rated voltage EN (1) [V]
400 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
32 [A]
Connection technology (1)
CAGE CLAMP®
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Solid sizes 1
0.08 … 2.5 mm² / 28 … 12 AWG
stranded, connectable 1
Fine-stranded wires 1
0.08 … 4 mm² / 28 … 12 AWG
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Side-entry wiring
Fire load [MJ]
0.088 [MJ]
Weight [g]
4.283 [g]
Width
17 mm / 0.669 in
Height
14.5 mm / 0.571 in
Length
20.5 mm / 0.807 in
Safety information 1
In grounded power lines
2
Images & drawings
3
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“222-413/K194-4045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+428.482572+55.53950
