231-303/026-000
231-303/026-000
    WAGO(万可电子)
    P=5.08mm
    接线端子 1x3P 间距:5.08mm 排数:1 每排Pin数:3
231-303/026-000 数据手册
Data sheet from 16.08.2013 Item no.: 231-303/026-000 Product description: FEMALE CONNECTOR 3 POLE PIN SPACING 5.08 MM / 0.2 IN WITH CODING FINGERS CLOSED END Produkt kann von Bild abweichen / product may differ Packing unit 100 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 5.62 g Color orange No. of connection Points 3 No. of potentials 3 pole count 3 Height 14.3 mm Height 0.563 in Width 16.74 mm Width 0.659 in Depth 26.45 mm Depth 1.041 in Pin spacing from 5.08 mm Pin spacing from 0.2 in Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 4 kV Current intensity EN 16 A Pollution degree 1 von 4 2 Measured voltage EN 630 V Measured shock voltage 4 kV Current intensity EN 16 A 2 von 4 Data sheet from 16.08.2013 Connection method CAGE CLAMP® CONNECTION Cross section [mm²] 0.08 - 2.5 mm² Wiring method solid Cross section [mm²] 0.08 - 2.5 mm² Wiring method fine-stranded Cross section [mm²] 0.25 - 1.5 mm² Wiring method fine-stranded (with ferrule and plastic collar) Cross section [mm²] 0.25 - 2.5 mm² Wiring method fine-stranded (with ferrule, without plastic collar) Cross section [AWG] 28 - 12 AWG Strip length from 8 mm Strip length to 9 mm Material group I Contact material Copper base alloy Contact surface tin-plated xxx-xxx/032-000 Strain relief plate 11,5 mm 3 von 4 Data sheet from 16.08.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 231-303/026-000 ABS 04-HG469925/1-PDA 400 16 0,08-2,5 231-303/026-000 BV 11915/A0 400 16 2,5 231-303/026-000 CCA 5764 250 16 0,08-2,5 231-303/026-000 CSA 154112-1466354 300 15 22-12 231-303/026-000 GL 17296-00HH 400 16 0,08-2,5 231-303/026-000 KEMA 2083746.02 250 16 0,08-2,5 231-303/026-000 KR HMB05880-EL003 250/400/600 12/16 2,5 231-303/026-000 LR 96/20035 400 16 0,08-2,5 231-303/026-000 RMR 11130002 400 16 0,08-2,5 231-303/026-000 UR E45171 600 15 28-12 231-303/026-000 UR E45172 300 15 22-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
231-303/026-000 价格&库存
很抱歉,暂时无法提供与“231-303/026-000”相匹配的价格&库存,您可以联系我们找货
  • 1+58.456941+7.57222
    • 1+8.06630
    • 100+7.82430
    • 200+7.59000
    库存:61
    231-303/026-000
    • 1+14.35320
    • 10+11.96640
    • 30+10.46520
    库存:66
