231-303/107-000
231-303/107-000
    WAGO(万可电子)
    P=5.08mm
    接线端子 间距:5.08mm 1x3P
231-303/107-000 数据手册
Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 . Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch Item No.: 231-303/107-000 . Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch . Marking . Business data Supplier WAGO Item no. 231-303/107-000 GTIN / EAN 4044918369879 Content 1 Order amount 100 Customer item number . Notes Item description:Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationIntegrated test portsCoding option available Technical data Miscellaneous Packaging type BOX Ratings per IEC/EN 60664-1 Rated voltage (III / 3) [V] 320 [V] Rated impulse voltage (III / 3) [kV] 4 [kV] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 Technical data Rated voltage (III/2) [V] 320 [V] Rated impulse voltage (III / 2) [kV] 4 [kV] Rated voltage (II / 2) [V] 630 [V] Rated impulse voltage (II / 2) [kV] 4 [kV] Rated current [A] 16 [A] Legend (ratings) (III / 2) Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) [V] 300 [V] Rated current UL (Use Group B) [A] 15 [A] Rated voltage UL (Use Group D) [V] 300 [V] Rated current UL (Use Group D) [A] 10 [A] Rated voltage CSA (Use Group B) [V] 300 [V] Rated current CSA (Use Group B) [A] 15 [A] Rated voltage CSA (Use Group D) [V] 300 [V] Rated current CSA (Use Group D) [A] 10 [A] No. of poles 3 Total number of connection points 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 Connection technology CAGE CLAMP® Number of connection points (connection type) 1 Actuation type Operating tool Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 1.5 mm² / … Fine-stranded conductor with ferrule without plastic collar 0.25 … 2.5 mm² / … Strip length 8 … 9 mm / 0.31 … 0.35 Inch Pin spacing 5.08 mm (0.2 in) Width 25.14 mm / 0.99 Inch Height 14.3 mm / 0.563 Inch Depth 26.45 mm / 1.041 Inch Contact type (pluggable connector) Female connector/socket Connector connection type for conductors WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 Technical data Mismating protection nein Locking of plug-in connection Screw flange Color orange Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.099 [MJ] Weight [g] 6.7 [g] Limit temperature range -60 … 85 °C WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 WAGO Kontakttechnik GmbH & Co. KG 5 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 . WAGO Kontakttechnik GmbH & Co. KG 6 Printview: Female connector; with screw flange; 3-pole; Pin spacing 5.08 mm / 0.2 in; codable; only 1 locking latch - Item No.: 231-303/107-000 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 7
231-303/107-000 价格&库存
很抱歉,暂时无法提供与“231-303/107-000”相匹配的价格&库存,您可以联系我们找货
  • 10+73.8848210+9.60479
  • 50+53.5696550+6.96388
  • 100+51.61837100+6.71022
库存:105
231-303/107-000
    库存:25
    231-303/107-000
    • 1+76.241601+9.91116
    • 1+22.05360
    • 10+18.78120
    • 30+16.83720
    库存:4
