Data sheet | Item number: 250-102
PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 2-pole; Pushin CAGE CLAMP®; 1,50 mm²; gray
www.wago.com/250-102
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
15.08.2020 Page 1/11
L = (pole no. x pin spacing) + 1.5 mm
Item description
Compact terminal strips with push-buttons
Push-in terminations of solid and ferruled conductors
Termination/removal of fine-stranded conductors via push-buttons
45° conductor entry angle provides easy, space-saving wiring
Custom color combinations
Terminal strips also available with spacers upon request
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
8 A
Hansastr. 27
32423 Minden
15.08.2020 Page 2/11
Rated current
8 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
5 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
5 A
Approvals per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1 mm²
Strip length
8.5 … 9.5 mm / 0.33 … 0.37 inch
Conductor connection direction to PCB
45 °
Pole No.
2
Total number of connection points
2
Total number of potentials
2
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
3.5 mm / 0.138 inch
Width
8.5 mm / 0.335 inch
Height
16.7 mm / 0.657 inch
Height from the surface
13.1 mm / 0.516 inch
Hansastr. 27
32423 Minden
15.08.2020 Page 3/11
Depth
12 mm / 0.472 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.4 x 0.75 mm
Drilled hole diameter with tolerance
1 (+0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
1
Material Data
Color
gray
Material group
I
Insulation material
Polyamide 66 (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.026 MJ
Weight
1.1 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
Packaging type
BOX
Country of origin
CH
GTIN
4044918647076
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
CCA
EN 60998
Hansastr. 27
32423 Minden
Certificate
name
NTR NL-
15.08.2020 Page 4/11
CCA
DEKRA Certification B.V.
EN 60998
NTR NL7449
CCA
EN 60947
NTR NL7100
CSA
C22.2
1132097
KEMA/KEUR
EN 60998
71-105258
KEMA/KEUR
EN 60947
2160584.18
VDE
VDE Prüf- und Zertifizierungsinstitut
EN 60998
40028888
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
UL
UL International Germany GmbH
UL 1059
Certificate
name
20180629E45172
Hansastr. 27
32423 Minden
15.08.2020 Page 5/11
Counterpart
Compatible products
check
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-151
www.wago.com/216-151
ferrule
Hansastr. 27
32423 Minden
15.08.2020 Page 6/11
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Marking accessories
Item no.: 210-332/350-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (240x); Height of marker strip: 3 mm; Strip length 182
mm; Horizontal marking; Self-adhesive; white
Hansastr. 27
32423 Minden
15.08.2020 Page 7/11
www.wago.com/210-332
/350-202
Item no.: 210-332/350-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (240x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/350-204
Item no.: 210-332/350-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (240x); Height of marker strip: 3 mm; Strip length
/350-206
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-720
www.wago.com/210-720
tools
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
EPLAN Data Portal 250-102
URL
Download
ZUKEN Portal 250-102
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 250-102
CAE data
PCB Design
Symbol and Footprint 250-102
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium
6 to current
version
Subject to
changes.
Please also
Hansastr. 27
32423 Minden
15.08.2020 Page 8/11
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
15.08.2020 Page 9/11
Inserting solid conductors via push-in
termination.
Inserting fine-stranded conductors via pushbuttons, 250 Series – 3.5 mm pin spacing.
Space-saving wiring, 250 Series – 5 mm pin
spacing.
Testing
Hansastr. 27
32423 Minden
15.08.2020 Page 10/11
Testing with 11 mm Ø test pin, on the
conductor, 250 Series – 2.5 … 3.5 mm pin
spacing.
Testing with 2 mm Ø test plug, touch
contact, 250 Series – 5 mm pin spacing.
Marking
Labeling via self-adhesive strips or direct
marking. Mixed-color terminal strips (with or
without spacer) are available upon request.
Hansastr. 27
32423 Minden
15.08.2020 Page 11/11
