Data sheet | Item number: 2616-1106/020-000
PCB terminal block; lever; 16 mm²; Pin spacing 10 mm; 6-pole; Push-in CAGE
CLAMP®
www.wago.com/2616-1106/020-000
L = (pole no. - 1) x pin spacing + 12.8 mm
Color:
Item description
PCB terminal blocks with lever-actuated Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Intuitive and tool-free operation
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Testing can be performed both parallel and perpendicular to conductor entry
Other variants can be requested via the WAGO sales department or, if necessary, configured at https://configurator.wago.com/: Direct marking,
Other colors,Other pole numbers
Data
Electrical data
25.02.2019 Page 1/5
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
1000 V
Rated impulse voltage (III / 3)
8 kV
Rated voltage (III / 2)
1000 V
Rated impulse voltage (III / 2)
8 kV
Rated voltage (II / 2)
1000 V
Rated impulse voltage (II / 2)
8 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
66 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
66 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.75 … 16 mm² / 18 … 4 AWG
Fine-stranded conductor
0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor with ferrule with plastic collar
0.75 … 16 mm²
Fine-stranded conductor with ferrule without plastic collar
0.75 … 16 mm²
Fine-stranded conductor, with twin ferrule
0.75 … 6 mm²
Strip length
18 … 20 mm / 0.71 … 0.79 Inch
Conductor entry angle to the PCB
0 °
No. of poles
6
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
10 mm (0.394 inch)
Width
62.8 mm / 2.472 inch
Height
37.2 mm / 1.465 inch
Height from the surface
33.2 mm / 1.307 inch
Depth
32 mm / 1.26 inch
Solder pin length
4 mm
Solder pin dimensions
1.2 x 1.2 mm
25.02.2019 Page 2/5
Solder pin length
4 mm
1.2 x 1.2 mm
Drilled hole diameter (tolerance)
1.7(+ 0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire terminal strip, staggered
Number of solder pins per potential
3
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Actuating element color
orange
Weight
55.341 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143707411
Approvals / Certificates
Country specific Approvals
Logo
Approval
Certificate name
CB
DEKRA Certification B.V.
NL-53125
CSA
70154737
KEMA/KEUR
71-104771
25.02.2019 Page 3/5
UL-Approvals
Logo
Approval
Certificate name
cURus
Underwriters Laboratories Inc.
E45172
Compatible products
ferrule
Item no.: 216-210
Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210
acc. to DIN 46228, Part 4/09.90
Item no.: 216-284
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90
www.wago.com/216-284
Item no.: 216-286
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
Downloads
CAD/CAE - Smart Data
PCB libraries
TARGET Library for WAGO PCB Terminal Blocks
Compatible with TARGET PCB Design Software Version 17.x
DesignSpark Library for WAGO PCB Terminal Blocks
Compatible with DesignSpark PCB Version 4.x or higher
EAGLE Library for WAGO PCB Terminal Blocks
Compatible with EAGLE PCB Design Software Version 6.x or higher
1.1.0
Oct 6, 2014
ZIP
27.1 MB
Download
2.1
Oct 6, 2014
ZIP
22.5 MB
Download
2.1
Nov 17, 2017
ZIP
23.9 MB
Download
URL
Download
CAD data
3D Download 2616-1106/020-000
25.02.2019 Page 4/5
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at 01788 568 008.
25.02.2019 Page 5/5
很抱歉,暂时无法提供与“2616-1106/020-000”相匹配的价格&库存,您可以联系我们找货
