2626-3360
2626-3360
    WAGO(万可电子)
    插件,P=12.5mm
    接线端子 间距:12.50mm 每排针脚数:10 排数:单排
2626-3360 数据手册
Data sheet  |  Item number: 2626-3360 PCB terminal block; 6 mm²; Pin spacing 12.5 mm; 10-pole; Push-in CAGE CLAMP®; 6,00 mm²; gray www.wago.com/2626-3360 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 1/6 Data sheet  |  Item number: 2626-3360 www.wago.com/2626-3360 L = (pole no. - 1) x pin spacing + 9.3 mm Item description PCB terminal strips with Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Ideal for panel feedthrough applications via operation parallel to conductor entry Testing can be performed both parallel and perpendicular to conductor entry Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 1000 V Rated surge voltage (III/3) 8 kV Rated voltage (III/2) 1000 V Rated surge voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Rated current 48 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 2/6 Data sheet  |  Item number: 2626-3360 www.wago.com/2626-3360 Rated current 48 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 38 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 38 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Solid conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor; with insulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with uninsulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with twin ferrule 0,25 … 2,5 mm² Strip length 13 … 15 mm / 0.51 … 0.59 inch Conductor connection direction to PCB 90 ° Pole No. 10 Total number of connection points 10 Total number of potentials 10 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 12,5 mm / 0.492 inch Width 121,8 mm / 4.795 inch Height 28,2 mm / 1.11 inch Height from the surface 24,2 mm / 0.953 inch Depth 18,5 mm / 0.728 inch Solder pin length 4 mm Solder pin dimensions 1,5 x 1 mm Drilled hole diameter with tolerance 2 (+0,1) mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 3/6 Data sheet  |  Item number: 2626-3360 www.wago.com/2626-3360 Mechanical data Mounting type Feed-through mounting PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material Data Color gray Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 53.1 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Packaging type BOX Country of origin PL GTIN 4055143897891 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 70146882 KEMA/KEUR EN 60947-7-4 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 71- Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 4/6 Data sheet  |  Item number: 2626-3360 www.wago.com/2626-3360 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71107864 Counterpart Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data PCB Design Symbol and Footprint 2626-3360 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 5/6 Data sheet  |  Item number: 2626-3360 www.wago.com/2626-3360 TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Handling Instructions Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.06.2020    Page 6/6
2626-3360
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特点,适用于高速光耦合器。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:广泛应用于数字通信、测量设备、工业控制系统等领域。
2626-3360 价格&库存
很抱歉,暂时无法提供与“2626-3360”相匹配的价格&库存,您可以联系我们找货
  • 7+122.67531
  • 25+116.83536
  • 97+111.51532
  • 250+106.61846
库存:694
2626-3360
    • 10+82.1269210+10.65590
    • 50+73.9403650+9.59370
    库存:694
