Data sheet | Item number: 264-737
4-conductor Mini rail-mount terminal block; 2.5 mm²; center marking; for DINrail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; green-yellow
www.wago.com/264-737
Color:
Data
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/12
Data
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Total number of connection points
4
Total number of potentials
1
Number of levels
1
Type of wiring
Front-entry wiring
Note (conductor cross-section)
12 AWG: THHN, THWN
Geometrical Data
Width
10 mm / 0.394 inch
Height from upper-edge of DIN-35 rail
24.5 mm / 0.965 inch
Depth
46.5 mm / 1.831 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Marking level
Center marking
Material Data
Color
green-yellow
Fire load
0.118 MJ
Weight
8.9 g
Commercial data
Product Group
9 (Std. Chassis Mt. Blocks)
Packaging type
BOX
Country of origin
DE
GTIN
4044918451956
Customs Tariff No.
85369010000
Approvals
/ Certificates
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/12
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7077
ENEC
EN 60947
2160584.02
Approval
ABS
American Bureau of Shipping
19HG1869868PDA
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
IEC 60998
91/20242
(E7)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UR
Underwriters Laboratories Inc.
UL 1059
Certificate
name
E45172,
sec. 6
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/12
Compatible products
Jumper
Item no.: 264-402
Comb-style jumper bar; insulated; 2-way; reduces conductor size to 1.5 mm; gray
www.wago.com/264-402
Item no.: 280-492
Alternate comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray
www.wago.com/280-492
Carrier rail
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 www.wago.com/210-112
mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 www.wago.com/210-115
mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-162
Steel carrier rail; 35 x 7.5 mm; slotted; 1 mm thick
www.wago.com/210-162
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copper- www.wago.com/210-198
colored
Subject to changes.
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
www.wago.com/210-505
Hansastr. 27
32423 Minden
29.12.2019 Page 4/12
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
Item no.: 249-139
Test plug module; without locking device; modular; for 4-conductor terminal blocks; gray
www.wago.com/249-139
Item no.: 264-368
End and intermediate plate; 4 mm thick; gray
www.wago.com/264-368
Item no.: 264-369
End and intermediate plate; 4 mm thick; orange
www.wago.com/264-369
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated
www.wago.com/216-106
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
check
End plate
ferrule
Subject to changes.
Item no.: 216-131
Hansastr. 27
32423 Minden
29.12.2019 Page 5/12
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Marking accessories
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-145
Item no.: 2009-145/000-002
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/12
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-145/000-012
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-145/000-024
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 209-290
Marker tags; not stretchable; plain; snap-on type; white
www.wago.com/209-290
Item no.: 248-501
www.wago.com/248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
Subject to changes.
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Hansastr. 27
32423 Minden
29.12.2019 Page 7/12
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 249-117
Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-117
Item no.: 709-153
Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent
www.wago.com/709-153
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material
www.wago.com/209-130
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Item no.: 280-432
Operating tool; made of insulating material; 2-way
www.wago.com/280-432
assembling
tools
Downloads
Documentation
Bid Text
264-737
May 30, 2017
doc
24.6 kB
Download
Feb 19, 2019
xml
3.1 kB
Download
doc - Datei
264-737
X81 - Datei
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/12
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 264-737
CAE data
EPLAN Data Portal 264-737
Download
WSCAD Universe 264-737
Download
Installation Notes
Assembly
Quick assembly keys prevent reverse
mounting.
Separate terminal strip and slide individual
terminal block laterally.
Remove terminal block from the carrier rail
with a levering action.
Inserting a conductor
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/12
CAGE CLAMP® connection
Inserting a conductor.
With ferruled conductors, it is necessary to
use a terminal block one size smaller than
the conductor’s nominal cross section.
Jumpered
Commoning with comb-style jumper bar.
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/12
Testing by touch contact to the
CAGE CLAMP® spring (limited to 0.5 A and
48 V test voltage) – test pins are not
protected against accidental contact.
Testing via CAGE CLAMP® on the current bar
(max. nominal current: 6 A).
CAGE CLAMP® clamps individual test
contacts.
The maximum test voltage is 400 V.
Separating groups via intermediate plates.
Combining 2- and 4-conductor terminal
blocks.
Marking via Mini-WSB Quick markers.
Application:
Easy-to-use miniature blocks that require
minimal enclosure space.
Marking
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/12
blocks.
Marking with T-marker tag (209‑290).
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/12
很抱歉,暂时无法提供与“264-737”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.86923
- 100+11.58234
- 国内价格 香港价格
- 4+29.607164+3.54090
- 20+28.9574720+3.46320
- 50+28.5862250+3.41880
- 125+28.21497125+3.37440
- 300+27.47247300+3.28560
