Printview: PCB terminal strip; 4 solder pins/pole; 8-pole; pin spacing 10 mm / 0.394 in; with operating
levers; without jumper slot - Item No.: 2716-108
0.394 in; with operating levers; without jumper slot
Item No.: 2716-108
PCB terminal strip; 4 solder pins/pole; 8-pole; pin spacing 10 mm / 0.394 in; with operating levers; without jumper slot
Marking
Business data
Supplier
WAGO
Item no.
2716-108
GTIN / EAN
4045454739324
Content
1
Order amount
15
Customer item number
Notes
High-current terminal strips with lever-actuated CAGE CLAMP®Tool-free opening and closing – fingers open/close
leversSeveral clamping units can be held open simultaneously – convenient for terminating multi-core cablesFour
solder pins per contact point for high mechanical stability600V UL for 12.5mm pin spacingPin and dimensions
compatible to high-current, screw-type terminal blocks
Technical data
Miscellaneous
No. of poles
8
Pin Spacing
10 mm (0.394 in %)
Total number of connection points
8
Total number of potentials
8
Color
gray
Ratings according to 1
IEC/EN 60664-1
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Overvoltage category EN 1
III
Pollution degree (1)
2
Rated voltage EN (1) [V]
320 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
76 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
76 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
320 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
76 [A]
Number of individual connection objects at the product
1
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
1.5 … 16 mm² / 16 … 6 AWG
Fine-stranded wires 1
1.5 … 6 mm² / 16 … 6 AWG
Fine-stranded wires with insulated ferrule 1
1.5 … 10 mm² / …
Fine-stranded wires with uninsulated ferrule 1
1.5 … 10 mm² / …
Strip length 1
12 … 13 mm / 0.47 … 0.51 in
Conductor entry angle to the PCB 1 [°]
30 [°]
Solder pin arrangement
in-line solder pin
Solder pin length [mm]
4.5 [mm]
Solder pin width A [mm]
0.95 [mm]
Solder pin width B [mm]
1.2 [mm]
Tolerance of drilled hole [mm]
1.6(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
2
Technical data
Contact plating
tin-plated
Fire load [MJ]
1.207 [MJ]
Weight [g]
74.44 [g]
Width
81.5 mm / 3.209 in
Height
33.3 mm / 1.311 in
Height from the surface
28.8 mm / 1.134 in
Length
30 mm / 1.181 in
3
Images & drawings
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“2716-108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+291.277841+37.63028
